Advice Needed H to H setup guide needed.
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
Hi guys.
Just bought a Geotrack II 99 H to H mount and I am struggling to get my head around the installation.
The 5 page instruction booklet fails to tell you what half of the adjustable parts are for and it says nothing about the wiring of the motor.
Does anyone have/know of a good step by step guide to installing these types of mounts? all of the guides that I can find seem to be about installing Diseqc motor.
Cheers.
Mickha
North West
Can you please post a picture, of your motor, as I can't find the Geotrack II 99 H to H mount.
Most motors are basic, a cable, from the LNB goes to one part of your motor, which should be labelled, the second goes directly to your satellite receiver, unless it's a 36v motor with 4 wire connections, in which case you will need a V-Box II.
Trust
Nijmegen Netherlands
probably the same as this one :
  • 413674-SG99 Manual.pdf
