28E feeds
danaddison
100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
Astra 28.2E
12568 H 15000
SkyWatcher
Comag SL65, Azbox Premium HD+, Azbox Mini Me, Techno mate Tm3000 D, Golden V8
London
12783/V/7500 GigatelHD Think it’s an S4C feed for an outdoor show.
SkyWatcher
London
Two up at the moment
12847/V/4798 ITA396 Feed1 2 audio channels Women’s Champions League Final practice and interviews in Spanish
12840/V/2271 ITA396 Feed2 2 audio channels Women’s Champions League Final practice no sound though Edit:there is now sound on both audio channels
mikeisyou
Feed Hunter
England
correct frequency:
28e
12688 V 2273
ID: ITA 396 FEED 2
28e
12696 V 4800
ID: ITA396 FEED 1
danaddison
Astra 28.2E
12568 H 15000
SkyWatcher
London
12845/V/7199 E-268 feed 1 Roller Hockey from Spain.
SkyWatcher
London
More Roller Hockey from Spain
12845/V/7199 Overon E385 Tv3
SkyWatcher
London
12844/V/9599 E261 feed 1 Spanish (Catalunya) football match
0200/1010/001
SkyWatcher
London
12845/V/7500 EDS807HD.1 shows a screen with a moving (zooming) logo of Generalitat de Catalunya and some low level audio.
Edit: now showing a courtyard with people.
@SkyWatcher as mikeisyou pointed out the frequencies you are posting are incorrect - check your LNB LO settings.
SkyWatcher
London
Do you know why the frequencies of other channels on the box appear to be okay in that case? I just did a clean scan on 28.2 on a blank satellite and got regular channels on their correct freqs. I’ve got the LNB setting on the box as Universal (9750-10600) which is I think the setting for a quad mini dish LNB. I don’t recall having changed anything recently. It’s a Golden V8 if that makes any difference or helps.
Do you know why the frequencies of other channels on the box appear to be okay? I’ve got the LNB setting on the box as Universal (9750-10600) which is I think the setting for a quad mini dish LNB. I don’t recall having changed anything recently. It’s a Golden V8 if that makes any difference or helps.
Looks like the same GUI as GT Media boxes, there is likely to be separate settings for each satellite but yes 9750/10600 is correct for Sky universal LNBs. Check the frequencies of channels above 11700MHz.
SkyWatcher
London
I’m 1 MHz out on a few of those but no more than that.
That's strange as there should be no reason it'd find correct frequencies for regular channels but incorrect ones for feeds.
SkyWatcher
London
Yeah very weird, I’ve deleted all the transponders and will keep an eye out for any changes. I’ve not had the younger relatives round recently either who have a habit of changing settings on things.
SkyWatcher
London
More Spanish women’s roller hockey but can someone please check my frequency is correct.
12695/V/7199 E-268 feed 1
0200/1010/0001
0200/1010/0001
Yes frequency is correct :Y
SkyWatcher
London
12696/V7500 EDS807.1HD Bloke with a microphone in a field of goats.
Also 12596/H/7500 Worcester Racing but signal dropping out a lot here in London
