Wanted Technomate TM 5402 HD
malsat
Hi
I'm wanting a TM5402HD or simular that will read Viacess Elite stars card (mature content)
Must have RF out
What you got ?
thanks
Hi
Must have RF out
What you got ?
thanks
Are you interested in this package only or would another CI box with modern Viaccess /Orca CAM be an alternative ?
7mdish
Milan, Italy
If he wants RF out, I doubt that modern receivers has one.
But a good solution could be adding an external RF modulator. In such case, Technomate has a very good one.
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Technomate has rf built in
7mdish
Milan, Italy
malsat
it goes to a distribution amp then to 12 TV's but some are old or I would do a modern box with HDMI modulator
A small brothel then.
You could try searching for a good second hand SF4008. Will run forever.
manic01
GB
7mdish
Milan, Italy
The TM5402 M4 is 2 years old
Yes, but basically it is not a latest generation receiver.
Also, if you must distribute satellite to many TVs, don't use the internal RF modulator. It is not a good one.
Using a good HDMI RF modulator it would be far better.
I have a Technomate RF modulator and it is very good, you can adjust signal level for the best result in your system, and you get a very high quality distribution.
Finally, you can choose the best satellite receiver, not only Technomate.
malsat
please delete
found one else where
Thank you
