EnoSat
- May 29, 2004
- Age
- 53
- Website
- enosat.euweb.cz
- TBS-5925/5220/5520SE , Dr.HD , Dreambox , Edision , Mutant
- Slovakia
Thanks for the info, @adonis1, but are you sure 11003 V,4828 is on 47.7E, not 46.0E?A new frequency activeted (11003V 4828)
I'm still receving 11003 V, 4828 on 46.0 but not on 47.7EThanks for the info, @adonis1, but are you sure 11003 V,4828 is on 47.7E, not 46.0E?
(There's a mux there with the same parameters).
There is a freq. below 11.20 Ghz on flysat chartIn their brochure, Eutelsat showed both up- and downlink bands, but the downlink was full 10.7...12.75 GHz band which doesn't match.
In the other Quantum topic (under satellite launches), the test signals reported led me to believe this is the frequency plan:
13.0...13.25 to 11.2...11.45 GHz
13.75...14.0 to 11.45...11.7 GHz
14.0...14.8 to 11.7...12.5 GHz
Then everything below 11.2 GHz or above 12.5 GHz must be from other satellites.
I know, but don't believe it!There is a freq. below 11.20 Ghz on flysat chart
I would like to know if the two signals in the upper band, which look like test carriers, are from this satellite or another.In their brochure, Eutelsat showed both up- and downlink bands, but the downlink was full 10.7...12.75 GHz band which doesn't match.
