C-Band Extended
fereshte
Bulgaria
2,30m prime focus dish with 3 LNBs - C ( Linear plus Circular ) and KU ( Linear ) ; 2,05m prime focus dish - KU circular and in future hopefully - ka band - 103E - 50W ; Octagon SF4008 UHD ; Edision Primo IP ; Inverto Flange white series ; Invacom quad; 36" motors; Especta and Moteck satellite positioners.
Bulgaria
Hi everybody! Do the 4581 40,5W channels are still there on only zoomoo remained? Because temporarily i put down my extended c band lnb and i still have no possibility to check.
Manikm909
Small'ish Dish Man
Kent, UK
Been out for the night so will have to double check tomorrow - i did notice a few days ago that 4581 L was missing
Decided to have a look now - Midnight 1st 8th, 2023.... 4581 L is still missing .
fereshte
Bulgaria
Bulgaria
Hi again. Unfortunately i do not have an opportunity to check 4581 on 40,5W? Is it still missing or it is back on air? Thanks!
Swapped back to Extended C today - Nothing showing on 40.5° West frequency 4581 L
@ 70.0° West
F1 racing - 3.810 H. PAL. fta.
2.2mtr PF. - Central UK.
About average reception quality today.
Manikm909
Small'ish Dish Man
Kent, UK
@ 70.0° West
Amazing . Nice one @John
@ 65° West Extended Cband. - Feed.
New for me ,
4536 H. 3846. 3/4. DVB-S2. 8PSK. BISS. ID: VTV SBT HD. Feed.
frankviana
Satellites/tv
Brazil
New for me ,
It is not a feed. It is a regular channel.
frankviana
Satellites/tv
Brazil
Blindscan now using LNBF Solid (3700 ~ 4800) and dish 5m (Brazil)
79 channels found:
Feed: 3860 V 34286 (16 APSK) -ID: Petrobras 2
No picture:
<?xml version="1.0" encoding="iso-8859-1"?>
    File created on Tuesday, 19 of September 2023, 13:58:20
    using osmini4k receiver running Enigma2 image, version 7.3,
    build 20230913, with the blindscan plugin
    Search parameters:
        Tuner A: Availink AVL6261 (DVB-S2X)
        Satellite: 65.0W Eutelsat 65 West A..Star One C1 C Band
        Start frequency: 10700MHz
        Stop frequency: 11900MHz
        Polarization: vertical and horizontal
        Lower symbol rate: 1000
        Upper symbol rate: 60000
        Only save unknown tranponders: no
        Filter out adjacent satellites: up to 3 degrees
        Scan duration: 186 seconds
<satellites>
    <sat name="65.0W Eutelsat 65 West A..Star One C1 C Band" flags="0" position="2949">
        <transponder frequency="3860000" symbol_rate="34286000" polarization="1" fec_inner="0" system="1" modulation="5" is_id="0" />
        <transponder frequency="4105000" symbol_rate="5000000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4111000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4116000" symbol_rate="3450000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="4142000" symbol_rate="1000000" polarization="0" fec_inner="0" system="0" modulation="1" />
        <transponder frequency="4150000" symbol_rate="2500000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4155000" symbol_rate="5000000" polarization="1" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="4510000" symbol_rate="2083000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4530000" symbol_rate="3750000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4535000" symbol_rate="3847000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4544000" symbol_rate="3730000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4548000" symbol_rate="3751000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4554000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4566000" symbol_rate="5083000" polarization="0" fec_inner="3" system="1" modulation="2" is_id="0" />
        <transponder frequency="4572000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4577000" symbol_rate="3750000" polarization="0" fec_inner="0" system="1" modulation="1" />
        <transponder frequency="4583000" symbol_rate="4800000" polarization="0" fec_inner="2" system="1" modulation="1" />
        <transponder frequency="4589000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4595000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4601000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4606000" symbol_rate="3750000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4607000" symbol_rate="4780000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4612000" symbol_rate="3750000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4613000" symbol_rate="6400000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4633000" symbol_rate="3750000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4640000" symbol_rate="6400000" polarization="1" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4650000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
        <transponder frequency="4687000" symbol_rate="3750000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4692000" symbol_rate="3720000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4696000" symbol_rate="7073000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4698000" symbol_rate="6668000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4704000" symbol_rate="2500000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="4705000" symbol_rate="7073000" polarization="1" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4708000" symbol_rate="5000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4720000" symbol_rate="10000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4732000" symbol_rate="9167000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4745000" symbol_rate="3750000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4749000" symbol_rate="3730000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4764000" symbol_rate="3750000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4769000" symbol_rate="3730000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="4774000" symbol_rate="3750000" polarization="0" fec_inner="3" system="1" modulation="2" />
    </sat>
</satellites>
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Excellent Frankviana!
I do not get all of those or transponders channels in North America, but I do get quite a bit.
There are some good commercial free movies that are on the 4555V transponder. Almost everything else I get on this satellite is in Portuguese.
                         Scan Report
< File created on Thursday, September 21, 2023 at 23:41:55 >
< Satellite =  65.0W C-band Star One C2 & Eutelsat 65 West A 65.1 W >
< Receiver =  sf8008 >
< Enigma2 Image = Tnap 5 >
< Kernel Version = 4.4.35 >
< DVB Driver Date = 2023-07-25 >
< Blindscan Frequency Range = 3625 to 4800 MHz >
< Blindscan Symbol Rate Range = 1 to 60 Msps >
< Blindscan Only Free Channels or Services? = False  >
< Tuner = Tuner A: Si2166D (DVB-S2X) >
< 'DVB-S2 8PSK 4510V / 2083 / 2/3' > Tp# 1
< (1)TV Assembleia />  1:0:1:E760:B1:E760:B850000:0:0:0:
< 'DVB-S2 8PSK 4531H / 3750 / 3/4' > Tp# 2
< (2)Record Paulista 1Seg />  1:0:C0:EB58:75A:75A:B850000:0:0:0:
< (3)Record Paulista HD />  1:0:1:EB40:75A:75A:B850000:0:0:0:
< 'DVB-S2 8PSK 4536H / 3848 / 3/4' > Tp# 3
< (4)VTV SBT HD />  1:0:1:EC40:762:762:B850000:0:0:0:
< (5)VTV SBT 1SEG />  1:0:C0:EC58:762:762:B850000:0:0:0:
< 'DVB-S2 8PSK 4544H / 3730 / 3/4' > Tp# 4
< (6)RECORDTV 1Seg TVMAR />  1:0:C0:ECD8:766:766:B850000:0:0:0:
< (7)RECORDTV LITORALVALE />  1:0:1:ECC0:766:766:B850000:0:0:0:
< 'DVB-S2 8PSK 4548H / 3751 / 2/3' > Tp# 5
< (8)PLAY TV />  1:0:19:1:0:0:B8511C4:0:0:0:
< 'DVB-S2 8PSK 4554H / 4781 / 3/4' > Tp# 6
< (9)RECORDTV 1SEG />  1:0:C0:BD38:5E9:5E9:B850000:0:0:0:
< (10)RECORDTV HD />  1:0:1:BD20:5E9:5E9:B850000:0:0:0:
< 'DVB-S2 8PSK 4555V / 2083 / 5/6' > Tp# 7
< (11)NCN-RADIO 1   (Radio #1) />  1:0:2:3:8:80:B850000:0:0:0:
< (12)NCN-RADIO3   (Radio #2) />  1:0:2:2:8:80:B850000:0:0:0:
< (13)NCN-RADIO2   (Radio #3) />  1:0:2:1:8:80:B850000:0:0:0:
< (14)HEVC Encoder1 />  1:0:1:3E9:8:80:B850000:0:0:0:
< (15)HEVC Encoder0 />  1:0:1:3E8:8:80:B850000:0:0:0:
< 'DVB-S2 8PSK 4566H / 5083 / 3/4' > Tp# 8
< (16)NOVO TEMPO 1-SEG />  1:0:C0:CB18:658:658:B850000:0:0:0:
< (17)NOVO TEMPO HD />  1:0:1:CB00:658:658:B850000:0:0:0:
< 'DVB-S2 8PSK 4572H / 4780 / 3/4' > Tp# 9
< (18)Record HD />  1:0:1:5C00:2E0:2E0:B850000:0:0:0:
< (19)Record 1seg />  1:0:C0:5C18:2E0:2E0:B850000:0:0:0:
< 'DVB-S2 QPSK 4577H / 3750 / 4/5' > Tp# 10
< (20)RFTV 1Seg />  1:0:C0:EA18:750:750:B850000:0:0:0:
< (21)RFTV HD />  1:0:1:EA00:750:750:B850000:0:0:0:
< 'DVB-S2 QPSK 4582H / 4800 / 2/3' > Tp# 11
< (22)Record News 1Seg />  1:0:C0:E858:742:742:B850000:0:0:0:
< (23)Record News HD />  1:0:1:E840:742:742:B850000:0:0:0:
< 'DVB-S2 8PSK 4588H / 4781 / 3/4' > Tp# 12
< (24)Record HD />  1:0:1:4780:23C:23C:B850000:0:0:0:
< (25)Record 1seg />  1:0:C0:4798:23C:23C:B850000:0:0:0:
< 'DVB-S2 8PSK 4594H / 4780 / 3/4' > Tp# 13
< (26)Record TV RS />  1:0:1:CAC0:656:656:B850000:0:0:0:
< (27)Record TV RS 1seg />  1:0:C0:CAD8:656:656:B850000:0:0:0:
< 'DVB-S2 8PSK 4600H / 4780 / 3/4' > Tp# 14
< (28)Record HD />  1:0:1:24E0:127:127:B850000:0:0:0:
< (29)Record 1seg />  1:0:C0:24F8:127:127:B850000:0:0:0:
< 'DVB-S2 8PSK 4607V / 3751 / 2/3' > Tp# 15
< (30)ATALAIA_SAT />  1:0:1:1:1000:2000:B850000:0:0:0:
< (31)XODO_FM   (Radio #4) />  1:0:2:2:1000:2000:B850000:0:0:0:
< 'DVB-S2 8PSK 4611H / 3750 / 2/3' > Tp# 16
< (32)TVAL />  1:0:0:1:0:0:B851203:0:0:0:
< 'DVB-S2 8PSK 4613V / 6400 / 2/3' > Tp# 17
< (33)RADIOUNAM />  1:0:16:12C:0:539:B850000:0:0:0:
< (34)CUAIEED />  1:0:16:2:0:539:B850000:0:0:0:
< (35)TVUNAM />  1:0:19:1:0:539:B850000:0:0:0:
< 'DVB-S2 8PSK 4649H / 30000 / 5/6' > Tp# 18
< 'DVB-S2 8PSK 4687V / 7073 / 3/4' > Tp# 19
< (36)TV TEM HD />  1:0:1:E800:740:740:B850000:0:0:0:
< (37)TV TEM 1SEG />  1:0:C0:E819:740:740:B850000:0:0:0:
< 'DVB-S2 8PSK 4688H / 3750 / 2/3' > Tp# 20
< (38)AUXILIAR />  1:0:1:A3C0:51E:51E:B850000:0:0:0:
< (39)TV ALEPE />  1:0:0:1:51E:51E:B850000:0:0:0:
< 'DVB-S2 8PSK 4692H / 3720 / 3/4' > Tp# 21
< (40)BAND TRIANGULO 1 SEG />  1:0:1:2:1:1:B851254:0:0:0:
< (41)BAND TRIANGULO HD />  1:0:1:1:1:1:B851254:0:0:0:
< 'DVB-S2 8PSK 4696V / 7073 / 3/4' > Tp# 22
< (42)TV TEM HD />  1:0:1:E940:74A:74A:B850000:0:0:0:
< (43)TV TEM 1SEG />  1:0:C0:E959:74A:74A:B850000:0:0:0:
< 'DVB-S2 8PSK 4699H / 6668 / 3/4' > Tp# 23
< (44)TV INTEGRACAO />  1:0:1:5AA0:0:2D5:B850000:0:0:0:
< 'DVB-S2 8PSK 4704H / 2500 / 2/3' > Tp# 24
< (45)TV ALBA HD />  1:0:0:1:1:0:B851260:0:0:0:
< (46)TV ALBA 1Seg />  1:0:0:3E8:1:0:B851260:0:0:0:
< 'DVB-S2 8PSK 4705V / 7073 / 3/4' > Tp# 25
< (47)TV TEM HD />  1:0:1:ED20:769:769:B850000:0:0:0:
< (48)TV TEM 1SEG />  1:0:C0:ED39:769:769:B850000:0:0:0:
< 'DVB-S2 8PSK 4709H / 5000 / 3/4' > Tp# 26
< (49)TRAS HD />  1:0:19:4EE8:73E:73E:B850000:0:0:0:
< 'DVB-S2 8PSK 4721H / 10000 / 3/4' > Tp# 27
< (50)Cultura FM   (Radio #5) />  1:0:2:5F:2D4:2D4:B850000:0:0:0:
< (51)Radio Mix   (Radio #6) />  1:0:2:6A:2D4:2D4:B850000:0:0:0:
< (52)TV INTEGRACAO UDI />  1:0:1:5A80:2D4:2D4:B850000:0:0:0:
< (53)TV INTEGRACAO AXA />  1:0:1:5C40:2D4:2D4:B850000:0:0:0:
< 'DVB-S2 8PSK 4732H / 9167 / 3/4' > Tp# 28
< (54)TVE 1Seg />  1:0:C0:E4F8:727:727:B850000:0:0:0:
< (55)TVE HD />  1:0:1:E4E0:727:727:B850000:0:0:0:
< (56)EDUCA BA />  1:0:1:E4E1:727:727:B850000:0:0:0:
< (57)EDUCA FM />  1:0:1:E4E2:727:727:B850000:0:0:0:
< (58)EM 1 />  1:0:1:E4E3:727:727:B850000:0:0:0:
< (59)EM 2 />  1:0:1:E4E4:727:727:B850000:0:0:0:
< (60)EM 3 />  1:0:1:E4E5:727:727:B850000:0:0:0:
< (61)TV BRASIL 2 />  1:0:1:E4E6:727:727:B850000:0:0:0:
< 'DVB-S2 8PSK 4745H / 3750 / 3/4' > Tp# 29
< (62)RECORD INT/RJ 1Seg />  1:0:C0:BD98:5EC:5EC:B850000:0:0:0:
< (63)RECORD INT/RJ HD />  1:0:1:BD80:5EC:5EC:B850000:0:0:0:
< 'DVB-S2 8PSK 4750H / 3730 / 3/4' > Tp# 30
< 'DVB-S2 8PSK 4765H / 3751 / 3/4' > Tp# 31
< (64)TV Cabralia 1Seg />  1:0:C0:2598:12C:12C:B850000:0:0:0:
< (65)TV Cabralia HD />  1:0:1:2580:12C:12C:B850000:0:0:0:
< 'DVB-S2 8PSK 4769H / 3730 / 3/4' > Tp# 32
< (66)Record SJRP 1Seg />  1:0:C0:E8B8:745:745:B850000:0:0:0:
< (67)Record SJRP HD />  1:0:1:E8A0:745:745:B850000:0:0:0:
< 'DVB-S2 8PSK 4774H / 3750 / 3/4' > Tp# 33
< (68)Record Interior 1Seg />  1:0:C0:E838:741:741:B850000:0:0:0:
< (69)Record Interior HD />  1:0:1:E820:741:741:B850000:0:0:0:<
Blind Scan Time = 4 Min. 24 Sec.
69 Channels ( TV = 63  Radio = 6)  33 of 33 Transponders Scanned.
frankviana
Satellites/tv
Brazil
I have an SF8008 too but I didn't see this detail (scan report) in the blindscan. Which image is using that shows the channels? I am currently also with OpenATV in it.
Thx
MeanMachine
Ku band dish with a Dreambox clone
South Asia
A modded SatDreamgr image used to have an option to save blind service scan report to /tmp directory in the past. Not sure about the current situation though.
frankviana
Satellites/tv
Brazil
Tnap5?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
TNAP is an abbreviation for The North American project. TNAP enigma2 images are designed for use in North America and may not perform well or may have features missing for other parts of the world. Custom built TNAP images are made from OpenPLi and other sources. Satellite Blindscan and other features are designed for fta enthusiasts with transponder filters stripped. Custom build explains why a Service Scan creates a found channel log that can automatically be saved to usb. Image downloads are available at legitfta.com.
frankviana
Satellites/tv
Brazil
How about send me a zip file?
Lexzie
TBS 5925 USB-tuner
The Netherlands
Manikm909
Small'ish Dish Man
Kent, UK
i think all E2 images, have this option when blind scanning, you choose to scan in the channels, or shows the transponders found - the report goes into a folder in your E2 receiver as a .tmp file i think
Where did you buy that LNB?
The SOLID range of LNB's are sourced from India as far as I know.
If you want to buy an extended C-Band LNB or LNBF you could try Ali Express or eBay.
