RC2000 dual axis antenna controller
Manikm909
Small'ish Dish Man
Kent, UK
thanks @John this is when the unit is just "resting" and not at any extremity
s-band
Essex
As John says, the error is due to lack of feedback pulses if it's trying to move but can't thereby preventing damage if the dish jams. If I forget to switch the motor supply on it takes about 2-3 seconds to trip. It will also trip if the pulse rate is too low e.g.if I reduce the motor speed too much.
I have something in the back of by mind that it would also trip if there are pulses when movement is not commanded. I think that happened when I forced an actuator to move manually. Check that you don't have any intermittent connections in the pulse sensor lines.
Manikm909
Small'ish Dish Man
Kent, UK
im still being hammered by this error - it doesnt happen during the dish move (it can, but its co-incidence) i.e i can move to 3w - to 19e for example, no problem, then after any amount of time, could be 5 minutes, or 2 hours, i'll suddenly hear a CLICK - and the error has happened - such a strange one.
if i turn the unit off (as it doesnt need to be on all the time, until i need to move the dish) - when i next switch on, the error will be there and need a reset. very very odd.
is there something i can clean inside perhaps, contact cleaner?? who knows - its a pain, but not a massive pain having to reset it every now and then.
s-band
Essex
I suppose it could be an EMC problem but it would need to be a big spike from something that couples to the lines. You could try something like a 10n capacitor across the pulse inputs to ground and/or a resistor, say 1k between inputs and ground. The resistor will drop the impedance of the inputs. Beware that the capacitor may make counting erratic if it is too big a value. It will depend on the cable length amongst other things.
A remote possibility might be that the actuator stops on the edge of giving a pulse and vibration tips it over. That seems very unlikely unless there's something loose in the actuator.
There are some internal connectors and many socketed ICs. This really is clutching at straws but you could try re-seating them all. There's risk of damage if not done correctly though. Another straw: if you disconnect the pulse inputs and leave it for along time and it still does it, perhaps it's an internal problem.
Manikm909
Small'ish Dish Man
Kent, UK
I checked the manual again . And have disabled simultaneous movement as it can overload the circuits or something like that ....it's been 35 mins. No error yet...
Manikm909
Small'ish Dish Man
Kent, UK
Nope ...36 mins after. Clunk. Error
You could try this - disconnect all outgoing cables from it , reset the RC2K, switch it back on but don't do any keypad button pressing and see if it still does the trip into the 'fault' error message ...
Or , - Have you got a spare functional actuator by any chance ? , doesn't need to be anything large or special and a short piece of good undamaged four core cable to do a temp bench set up . Adjust the temp actuator physical limits up with a separate supply for max in and out safe travel. Go through the RC2K software limits set up again and see what results you get , a bit of a faff i know but it might highlight the problem area ie: RC2K internals or External cables and actuator faults.
Manikm909
Small'ish Dish Man
Kent, UK
Thanks @John .
I had a thought this morning. When it first started happening I did do a reset and I also switched the sensor wires over. To no avail.
I'm now thinking of swapping over the elevation and sensor wires over with azimuth . To see if the problem follows / to see if I get the elevation fault still or if I get an azimuth error instead. Then I'll know if it's the rc2k or the actuator /wiring.
I do have a spare 12 inch actuator to try your test also.
What I've noticed is that if I reset the error after any dish movement and then don't move the dish again I don't think the error comes up. I think I'm correct in saying that .
Thanks everyone
Thanks @John .
Thanks everyone
Yep, good idea regarding swapping over the AZ for the EL, i'd leave the suspected AZ 4core wiring disconnected as well for the test. :Y PS, swapping the pulse cable polarity around shouldn't make any difference
Check the green connector blocks at the back are fully home, they pull out to make it easier to connect any wires. Might be worth pulling them out and back in again. Check all screws are tight etc..
You could always email RC, last time I did they were very helpful.
Manikm909
Small'ish Dish Man
Kent, UK
i dont know if im tempting fate or not, but since re-seating the green blocks i've not had the issue!
thank you @scopus
