Eutelsat 10B
dreamsat
germany
11323 H 2000 DVBS2/QPSK 1/2 AOL
Feed at 11330 7200 DVBS2/8PSK 3/4
dreamsat
germany
10823 H 26760 DVBS2/QPSK 2/5 "CNNI Europe HD"
10897 H 30130 DVBS2/QPSK 2/3 Data
dreamsat
germany
11046 H 26775 DVBS2/QPSK 1/4 "CNBC GLOBECAST OSN Backup"
Satfaca
Melmac (46N, 14.5E)
Melmac
This new 10B is p.ss..g me off.:-ohcrap
I've been trying to research the mess with the signals & beams in the 11.300-11.450 range but issues are getting even bigger.
For instance 11.380 V (FS lists it as 11.382V); I locked two different streams here. Most of the time is this one:
But I also got this one:
It looks like alternating between transport & Continous mode. Or?!
I've gone and finally installed the TS Analyzer to get some more info... everything reminds much on the 11.376 H & 11.377 V listed on FS.
Satfaca
Melmac (46N, 14.5E)
Melmac
More crazy stuff here ... 11.376 H, listed as CNN Europe on FS ... once I get it analyzed as CNN, next time as CNBC. :confused
Satfaca
Melmac (46N, 14.5E)
Melmac
I get considerably more dB so this cannot be wide beam as displayed by FS.
EnoSat
enosat.euweb.cz
Slovakia
The biggest problem with current cards is that they do not read the mode intended for identification.
For example, 11375.58 H from the card uses 3 modes (Activated option - Update modulation info):
capture_009_26092023_220313.pngcapture_008_26092023_220151.pngcapture_007_26092023_220148.png
but the card analyzes only one mode (stream)
When you feed the same signal to the e2 box, it analyzes another mode (identification)
screenshot_19700102130042.jpgscreenshot_20230926221458.jpgcapture_001_26092023_223557.png
or
where the spot number is already indicated
PS:1 Subsequently, addressing of the processing of the stream(s) on the IP bus of the modem begins
EnoSat
enosat.euweb.cz
Slovakia
PS2: My old card works very unreliable when selecting modcode (if it works at all), but it is possible to initially separate individual streams
capture_007_26092023_230449.pngcapture_005_26092023_230008.pngcapture_002_26092023_231637.png
Recently, Eutelsat website shows downlink coverage maps for 10B as well:
"HTS Downlink" and "GMS Downlink" (what is GMS?) seem to be composites of the many spot beams that both HTS payloads provide.
A map for Widebeam Ku-band, for continuity of 10A existing customers as they say it, is still missing.
Satbeams shows it, however.
Thanks, @hvdh for the link.
GMS-maybe Google Mobile Service(?)
Joolz
1m Astro 55°E - 63°W
astra19
98cm motorised technomate. 50e to 34.5w
Europe
"OSN BACKUP" suggests maybe it's used to OSN in MENA?
EnoSat
enosat.euweb.cz
Slovakia
Do not forget that it is not broadcasting, but testing of transponders for work with DVB-IP
Nakudo
Eutel sat 10B &eutelsat 3b
Uganda
Hallo, this is Robert from Uganda, can you help get me the strong TPs for Eutelsat 10b & Eutelsat 3b on c-band.Thanks
SimonE
Gloucestershire, UK
Robert, on the 3E I get Nyota TV on 4032 RHC and on 10E I get MonCloud TV on 4027 RHC and Tchad TV on 3860 RHC. These must be the easiest to lock as I only have a 1.2m CM dish.
Nakudo
Uganda
Thanks, but I have a 1.8m dish and I wanted to get East African local channels.
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Exactly, these are the strongest transponders on the two satellite positions :)
1_0_1_101_1_1_1F8FC0_0_0_0_20170323055424.jpg1_0_1_101_1_1_1F8FC0_0_0_0_20170323055433.jpg1_0_1_1_0_0_658F13_0_0_0_20170323053643.jpg1_0_1_1_0_0_658F13_0_0_0_20170323053653.jpg
suedschwede
DE
current scans on the position and what/how many channels are found (date/time is not correct :( )
