Free french channels on 5 west
abrasat
T90
Andorra
I have good signal on 5 west (for instance 13.3 dB on 11096 V, 29950, 3/4, 8PSK), but since a couple of weeks no more signal on the transponders with free french channels 12648 V, 29500, 8/9 or 12732 V, 29500, 8/9. Did these 2 transponders reduced their signal strength in the last months?
My SAT receiver is able to handle multistream, that is not an issue
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
all working as normal ..may be something wrong with your system !
abrasat
T90
Andorra
Thanks for the feedback. Do you have the same signal strength on all transponders on 5 west? Could you please send your multistream settings for the 2 transponders above? These transponders have FEC=8/9, maybe they need more signal.
Or maybe my Inverto Black Ultra Single LNB has problems with these upper frequencies... But these channels worked some months ago, and then I had a storm and had to re-adjust the LNB
abrasat
T90
Andorra
Ok, thanks. According to the lyngsat links above, the C/N lock for these transponders is 10.7 dB, much higher than the C/N lock of 6.6 dB for other transponders on 5 west
All fine at Heathrow with the 80cm and GTMedia Combo.
abrasat
T90
Andorra
Thanks. According to the footprint of the Transalpine beam it should be the same signal strength in London as in my location Frankfurt/Germany. The other transponders from the Transalpine beam are ok.
I first thought that maybe the LNB does not work on high-band anymore, but as far as I remember I have signal on 12585 H, 8PSK, 35500, 2/3 , also a multistream transponder (I will check the signal tonight).
By the way, the C/N lock for 12585 H is according to lyngsat only 6.6 dB
12585H
I will also check my settings.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Hola 'abrasat' , your map shows Alicante included. Reception here with 5ºw always ok-
Dish = 1.2m.
Good luck. :Y
abrasat
T90
Andorra
Could anyone please post the results of the scan of 5 west, with the signal strength for each transponder?
All transponders or just FTA French (inc multistream) ?
It's currently very overcast here.
pipino
Back from the dead
you could do basic checks with your system before posting here I think <_< ..we did check for you and confirmed it's all working without a problem !
smithysmudge
Viark DRS2
Alloa
You should get those transponders no problem at your location in Frankfurt as I can receive them load and clear on a 1.2m gibby, location central Scotland which is outside the footprint
Here's what the MIS muxes look like on 5.0W.
A new mux was activated: 12627 H, 35300, 2/3,8PSK, MIS: 1,2,3,5.
(Could anyone please post the results of the scan of 5 west, with the signal strength for each transponder? )
Eutelsat 5 West B @ 5° W 25th October 2023 10:0am BST
SX88 SE-4K+ 88cm mesh dish South West Essex UK
====signals strenght % quality % TV & Radio signals
10972 V 29950 ==93%====100%
11013 V 35300 ==92%====98%
11016 H 35300 ==93% ===100%
11054 V 29950 ==92%===100%
11096 V 29950 ==92%===100%
11179 V 35300 ==91% ===98%
11471 V 29950 ==94%====100%
11472 H 9900 ===93%====100%
11480 H 3167====90%====100%
11512 V 29950===93%====100%
11554 V 29950===94%====100%
11637 V 35295===93%====100%
11675 H 35300===95%====100%
11679 V 29950===93%====100%
12585 H 35500===94%====100%
12648 V 29500===95%====100%
12732 V 29500===94%====100%
I hope this helps you...
abrasat
T90
Andorra
Thanks all for the useful feedback.
I could not find anything wrong with my system settings so I ordered a new LNB to be sure that the LNB is not the problem.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Are you sure the skew of the LNB is still correct and the dish did not slightly move due to some wind?
gdf68
1m dish Digipower SG2100A TM2600 GM twin Lnb, GT media 8uhd, vuo duo, Xtrend 8500. GM SR525HD Nvidia Shield Sport feeds
Liverpool
Out of curiosity I'll check I'm in NW Liverpool, 100cm dish should I receive this ok , never understood footprints.
Mickha
North West
Footprints are satellite maps, showing roughly what size dish, you need, to get transponders, and if they're even possible, in your area.
This one is copied off lyngsat:
Adam792
Cheltenham
I'm using an 80cm dish here in the west of England, personally I think the French multistream transponders are a little bit weaker as of recent. I'm getting around 13.5dB C/N max now where I used to get it to peak up at around 15.5 before, so that's a couple of dB down. I've just tried a second 80cm dish with the same results. If your signal is marginal or you're using a smaller dish like me, that could be enough to make borderline reception drop off the cliff-edge. I'm still getting a few dB higher than the lock point so it's still fairly strong.
I've also noticed that since they've tweaked 11480H (to reduce the symbol rate a bit), it's not quite as much of an LNB cap-melter as before!
