sophie101
- Apr 20, 2015
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
- belgium
After the factory reset, I did am Auto Disquc setup like you suggested above.
It found 19.2e and 13e,
How can it find 5W before and nothing else. Then I do a factory reset, and now it can only find 19.2 and 13. This is nonsensical.
but not
5W or 28.2e.How can it find 5W before and nothing else. Then I do a factory reset, and now it can only find 19.2 and 13. This is nonsensical.
