Advice Needed Image for Edison MIO+ MS 4k box
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
After the factory reset, I did am Auto Disquc setup like you suggested above.
It found 19.2e and 13e, but not 5W or 28.2e.
How can it find 5W before and nothing else. Then I do a factory reset, and now it can only find 19.2 and 13. This is nonsensical.
EnoSat
enosat.euweb.cz
Slovakia
Add manually 28E and 5W to 19E and 13E, maybe the reference frequencies no longer agree with the current ones.
sophie101
* Currently
belgium
I tried this earlier before the reset, and it did not work. Will try again.
EnoSat
enosat.euweb.cz
Slovakia
After automatic detection of 19E and 13E, add the remaining 28E and 5W
sophie101
* Currently
belgium
Did you what said.
Oh fantastic. 28e and 5w coming in. Also the MIS feeds by the looks of it :cool:
sophie101
* Currently
belgium
Next step is to fix the audio.
The Edision is very low even at 100%, which means I have to turn the TV set volume up very high. Because I suffer from severe Tinnitus I end up with a loud volume of background frequencies that really hurts my ear, and makes the tinnitus louder than the audio.
Worryingly, my son who does not have tinnitus, and has perfect hearing, also complains that the volume is too loud and gives him ear ache when watching it.
Watching Channel 4 ( 28.2e ) and the film audio is so low we cannot really hear it at any volume, but the volume during the advertisment break is quite audible. This is really weird. I just plugged the old TV reciver back in and the same channel does not cause tinnues, is at a normal volume, and does not hurt our ears.
Poor sound is the killer.
EnoSat
enosat.euweb.cz
Slovakia
Automatic volume adjustment - OFF
sophie101
* Currently
belgium
EnoSat
enosat.euweb.cz
Slovakia
Hmm, 6.4 . Maybe that's why network search isn't working properly.
sophie101
* Currently
belgium
Could be.
Also the box is not getting the 5w multistream any more.
Before the factory reset I had MS for the Italian channels on 5w. Not anymore. Weird. Will try again tomorrow evening.
Also I need to install a new image. This 7.4 is too old.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Also I need to install a new image. This 6.4 is too old.
Do not try to do this, you are too newbie for such a complicated procedure.
The receiver may simply not start anymore, if you do it the wrong way.
Edision should work with OpenATV 6.4 for multistream from 5°W.
I will show you later with a screen shot how to find TF1, France2, M6 etc without blindscan.
sophie101
* Currently
belgium
Why do you say this?
Because I am crap with GUIs? True, I am. No patience with GUI. I grew up when there was only a CLI. I do appreciate your concern.
Currently I gave a box with:
- Broken wifi.
- Causes severe tinnitus. ( Thus unsable).
If the tinnitus cannot solved, then the box sent back, because I cannot use it. I still have the T this morning: It kept me awake all last night.
If flashing a newer firmware/image/whatever solves the tinnitus cause thn I will the Edision. If not, good by Edision ( and never an enigma2 again).
Does installing an image actually re-install the O/S, or is it just installing an application?
sophie101
* Currently
belgium
Eag just checked:
"Enigma software, is an application..."
It's written in Python and C++ ( did C++ back in the mid 90s but have forgotten most of it)
I will manage.
Thanks. This will be great. I tried scanningg TPs ( in MS mode) from the details on kingofsat, but I do not know where some settings are entered in. I am sure that there is an easier way.
LeBelge
Belguim
Menu —> Setup —> Reception —> Signal Finder
If the PLS Code is wrong there will be no signal.
le2
We will fix the audio issue (tinnitus) once all French channels are found and working.
Now I want you to show us that TF1 works.
p.s.
be patient, I also have a family life
sophie101
* Currently
belgium
sophie101
* Currently
belgium
Tried with your settings, but did not find any channels.
LeBelge
Belguim
Can you please try with
Symbol rate 29500
Frequency 12733
