Help Required Enigma2: How can one disable HBBTV?
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
I see thatHBBTV is enabled on a vewiing card. I have no need to HBBTV. Can we disable this in Enigma2? I'm using OpenVIX 6.4 if it is relevant.
Fangs for any ideas!
S.
Mickha
North West
HBBTV might be pre installed, as a plugin, have you chacked the plugin options, to try and delete it?
sophie101
* Currently
belgium
Thanks. Found it.
It's not in the plugin list, but is installed:
# opkg list|grep hbb|awk '{print $1}'
enigma2-plugin-extensions-hbbtv-webkit
enigma2-plugin-extensions-hbbtv-webkit-dbg
enigma2-plugin-extensions-hbbtv-webkit-dev
enigma2-plugin-extensions-hbbtv-webkit-src
enigma2-plugin-extensions-openhbbtvbrowser
openhbbtvbrowser
webkit-hbbtv-plugin
webkit-hbbtv-plugin-dbg
webkit-hbbtv-plugin-dev
I am very unfamiliar with the packages, and Embedded Linux.
Which one ought to be removed, or even better configuted to disable hbbtv for specific viewing card that I use in OScam?
EnoSat
enosat.euweb.cz
Slovakia
HbbTV does not use OScam, but an internet connection.
sophie101
* Currently
belgium
Yes, I realised, but my Fransat card uses OScam, and some how this is communicating with hbbtv, which in turn is communicating with a Fransat server somewhere, and I wish to interrupt this part of their communicate somewhere.
Looks like these are the IPs used by Fransat:
142.250.179.232:443
52.84.174.70:80
As a workaround I have dropped routing for these IPs.
route add -host 142.250.179.23 reject
route add -host 52.84.174.70 reject
sophie101
* Currently
belgium
I have an excellent idea.
I need to disable the long press on the coloured buttons so that it does not try to start HBBTV :)
I think bindings are in /usr/share/enigma2/keymap.xml , but I do not understand the file,
This shows a long press on the red button, but not an action associated with it.:
# grep -i red_long /usr/share/enigma2/keymap.xml
        <key id="KEY_RED" mapto="red_long" flags="l" />
EnoSat
enosat.euweb.cz
Slovakia
142.250.179.232:443
52.84.174.70:80
Google and Amazon IP
FranSat call
Address : fransat-frontend.wiztivi.io
Address (fransat-frontend.wiztivi.io) is not a valid IP address
Lookup in DNS .. resolved : 18.66.27.26
sophie101
* Currently
belgium
I think I found it, but the references to Dreambox are a bit odd because I have a n Edision. Did this keymap.xml start life in a Dreambox?
<map context="InfobarRedButtonActions">
<device name="dreambox advanced remote control (native)">
<key id="KEY_RED" mapto="activateRedButton" flags="l" />
</device>
</map>
sophie101
* Currently
belgium
FranSat call
Yep, one is Google and one is Amazon. One geolocates to Ile de France Paris.
The 18.x.x.x. is:
$ host 18.66.27.26
26.27.66.18.in-addr.arpa domain name pointer server-18-66-27-26.vie50.r.cloudfront.net.
rodscha
If you are using the French bouquet,HBBtv is useful for Arte,w9,tfx and C8
it gives you replay,info on channel & lots of things to watch,very useful.especially on Arte (no ads pollution)
red button gives website,blue gives "back to the start" function. I use it a lot.
sophie101
* Currently
belgium
Absolutely agree, but it means Fransat can use my data to profile me. Which object to.
I don't recall too many ads on Arte. I use the feed from 19.2 or 13.
Fisty McB
See my signature...
County Tyrone, N. Ireland
I thought OpenVix didn't have HbbTV by default, or am I wrong?
sophie101
* Currently
belgium
You could be right.
i just realised my earlier search was wrong, because I did an opkg list of an opkg list-installed.D'oh. I shall have a look this evening.
However, a long press on the red button establishes a connection with two IP addresses ( google and amazon ), which means something is happening.
sophie101
* Currently
belgium
Hi, Just looked and the webkit is pre-installed in the openvix image:
# opkg list-installed|grep -i hbb
enigma2-plugin-extensions-hbbtv-webkit - 2.0-r0-69+56f9556-r0
webkit-hbbtv-plugin - 2.0-r0-69+56f9556-r0
Nowt else.
