40.5W SES6 & NSS806
Reported on 40W mid April on Flysat..
Manikm909
Small'ish Dish Man
Kent, UK
4175 - V - 9699 - now, GCUK ENC 7 feed (biss)
Just checked it out, I doubt if anywan will get a picture from it.
Is this still running at the moment [21.00hrs] with you Ladies down South - Nothing seen here up in the Midlands.
rs100
CM 1.0 DISH
Checked it just now at 10.52am - a bit hit and miss on the 2.2. No interference showing on the Promax to upset it, seems a bit sensitive to accurate polarity setting today, clear blue sky to satellite.
Promax shows 10.5 to 11dB max, slight fluctuations. CS / EBSPro showing 8.5 dB or so.
Hi what receiver is that your using thanks
My main receiver is a GTMedia GTCombo, the reference to the Promax is the Promax HD Ranger+ signal meter
Manikm909
Small'ish Dish Man
Kent, UK
can ANYONE manage to bring in this TP (T2MI) on their Enigma2 receiver
CANAL 1 (HD version)
They changed it to multistream in April, and ive only just noticed im no longer receving.
Ive tried it on both Octagon SF8008 and Edisiion MIO 4K - nothing, if i try my non E2 GTMEDIA COMBO, it works fine, so its not a signal issue.
im using PLP: 101, and 2031 for the code....(VSID i think)
I just dont get it
ive even tried a channel list with the correct parameters from DREAMSET EDIT tool....nothing.
doing my nut in!
ALSO - can a DVB-S2 (not X) tuner show a multi stream channel, but just not scan it in...?
EDIT! AHHHHHH!
i was using the wrong parameters....
PLP ID: 101
T2MI PID: 64
Now i see the "RTVC PLP 101 on PID 64" bit of link
DOH!!!!
Manikm909
Small'ish Dish Man
Kent, UK
you're not kidding @John my 1.8 is bouncing about all over the place!
halliwell
galaxy
Ger
Hello,
I can confirm!
root@tracks:~#  /root/CrazyCat-scan-s2-561c35ce2845/scan-s2 -c -a 2
API major 5, minor 10
ERROR: Cannot open rotor configuration file 'rotor.conf'.
using '/dev/dvb/adapter2/frontend0' and '/dev/dvb/adapter2/demux0'
>>> parse_section, section number 0 out of 0...!
service_id = 0x0
service_id = 0x64
pmt_pid = 0x64
service_id = 0xC8
pmt_pid = 0xC8
service_id = 0x12C
pmt_pid = 0x12C
service_id = 0x190
pmt_pid = 0x190
service_id = 0x1F4
pmt_pid = 0x1F4
service_id = 0x258
pmt_pid = 0x258
service_id = 0x2BC
pmt_pid = 0x2BC
  CA ID     : PID 0x4749
  VIDEO     : PID 0x00C9
  AUDIO     : PID 0x00CA
  AUDIO     : PID 0x00CB
  AUDIO     : PID 0x00CC
  AUDIO     : PID 0x00CD
  CA ID     : PID 0x4749
  VIDEO     : PID 0x012D
  AUDIO     : PID 0x012E
  AUDIO     : PID 0x012F
  AUDIO     : PID 0x0130
  AUDIO     : PID 0x0131
  CA ID     : PID 0x4749
  VIDEO     : PID 0x0065
  AUDIO     : PID 0x0066
  AUDIO     : PID 0x0067
  AUDIO     : PID 0x0068
  AUDIO     : PID 0x0069
  CA ID     : PID 0x4749
  VIDEO     : PID 0x02BD
  AUDIO     : PID 0x02BE
  AUDIO     : PID 0x02BF
  AUDIO     : PID 0x02C0
  AUDIO     : PID 0x02C1
  CA ID     : PID 0x4749
  VIDEO     : PID 0x01F5
  AUDIO     : PID 0x01F6
  AUDIO     : PID 0x01F7
  AUDIO     : PID 0x01F8
  AUDIO     : PID 0x01F9
  CA ID     : PID 0x4749
  VIDEO     : PID 0x0259
  AUDIO     : PID 0x025A
  AUDIO     : PID 0x025B
  AUDIO     : PID 0x025C
  AUDIO     : PID 0x025D
  CA ID     : PID 0x4749
  VIDEO     : PID 0x0191
  AUDIO     : PID 0x0192
  AUDIO     : PID 0x0193
  AUDIO     : PID 0x0194
  AUDIO     : PID 0x0195
WARNING: filter timeout pid 0x0011
Manikm909
Small'ish Dish Man
Kent, UK
er - what are you confirming....
