tve uhd
Teledeporte moved to RGE1 (regions) now ..still a work in progress on RGE2
done...all this noise for 10Mbps !!??
I just done a scan and getting RTVE UHD1 and with Teledeporte HD on the same frequency (554 MHz) - with DKISS also. No sign of UHD 2 yet...
Still says it is DVBT and not DVBT2...
Think I got better signals when I could get the testsignals from the mast near Valencia - 50kms away
UHD2 will become available later this year, when we are going towards the Olympic Games.
presumably they wil need to make more changes to the RGE2 mux to have more bandwidth?
the mux needs to stay DVB-T otherwise when it becomes DVB-T2, DKISS loses audience because of more incompatible devices.
I just done a scan and getting RTVE UHD1 and with Teledeporte HD ±+±±±++++++++
Yes, same here with TDT near Alicante.
Any scan rtg1 mux if it have more uhd channel ?
there is no UHD on RGE1 (Regionals) only La 1 UHD on RGE2 (Nacional)
On the transmitter near Valencia they had the two RTVE UHD channels, on TDT frequency 41 for the last few months.
But since Sunday, that frequency closed , and only the one UHD is now transmitting on all my local masts, with no sign of the second UHD channel anymore.
It only la 1 uhd and la2 uhd plan and antenna 3 uhd ?
Only La 1 UHD.
tdp UHD Should become available later this year. But I have no clue in Which Multiplex they can add that channel because every mux is at 100% capacity
Just updated, TDT (terrestrial):-
Labelled... 'La1 UHD'...
666 MHz Cartagena/Murcia.
Previous 'TVE UHD' + 'UHD 2' still scan in on 530 MHz.
The TVE1 UHD and 2 UHD from the main mast covering Valencia have returned on channel 41 / 634000 in DVBT2.
The other La 1 UHD s that i can get from my more local masts on 31 / 554000 and 21 / 474000 are only in DVBT
it same mux rtg2 it two tve1 uhd or la 2 uhd >?
SD versions were switched off last night, so by now all channels are in HD
