Octagon sf4008 4k uhd e2 updates 26.05.2019
OCTAGON SF4008 4K UHD E2 Updates 26.05.2019
- [sf4008] update ir drivers
- New Online/Local Flash Menu
- New Complete Backup Menu
- Install Full Backup Image from Power Button Standby Menu
- [multiboot] add MessageBox before reboot
- RDS Info for Radio Ch. fix.
- exteplayer3 fix.
- webkithbbtv update
- MIS/PLS LCN Multistream Plugin Support
- python-youtube-dl update
- Add GPT usb disk support in fastboot
- Change the default bootargs in fastboot for sf4008
- So it can enter recovery even lost bootargs partition for sf4008.
- Fixed a assert error during boot and remove some debug infos
- Remove the debug info for kernel print
- [rt8723bs] disable powermanagement
- Software Manager (Flash Online):
- fix BSOD then get io error open STARTUP files
- about fix startup infos for new multiboot images
- Fixed noise when playing 32bit PCM Audio
- Sound problem fixed
- [linux] Add Hauppauge DualHD bulk models
- Add Inverto IDLU-UST110-CUO4O-32P (Unicable)
- add missing dat time changes
- [FileCommander] add path to script parameter
- [FileCommander] fix title for translation
- [FileCommander] fix possible bs
- [FileCommander] add setTitle in FileCommanderContextMenu
- eDVBFrontendParameters FEC add.
- scanStatusChanged update
- eDVBTSTools update
- EPGlist update
- Movielist update
- Addons key actions update
- Add missing FECs for dvb-c2/t2/s2
- ServiceScan update
- ScanSetup update
- Transponder parameter update
- Fix rewind freeze
- Kernel Update & Modify
- [linux] fix mt7601u detection
- [submodule] update realtek rt8188fu
- rt8188fu change git with more updates for older kernels
- add wifi rtl8188fu
- [linux] fix issue dib7000 add patches from 4.4.179
- dvb-usb-linux_4.4.179.patch
- dvb-usb tuner with dib7000 chip
- VirtualKeyBoard fix merge issue
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
OCTAGON GERMANY SUPPORT
Quick question
Is there a button on the remote that downscales the HDMI resolution ?
I've acquired one of these and - I believe - it is currently locked to UHD output, so the screeen shows 'not supported'.
I really don't want to reflash until I've seen something from satellite.
If it has WebIF you may be able to change the settings from there.
Thanks. I've downloaded open8 (latest today) firmware, and managed to blind navigate through the boot menu to get it to display a screen.
Will report back, but it is a really weird animal as it is attempting to scan services below the lower IF limit on 26 East.
OK, first impressions.
Loving the machine, the Open8 package is doing its job.
All tests passed,
I suspect the blind scan was never implemented as it would have made the SF8008 redundant.
All tests passed,
I seem to recall some historic discussion about the lack of availability of blind scan for one of the Octagon E2 models?
Never resolved by Octagon for the SF4008 apparently but easily implemented in the SF8008. Looks like a deliberate marketing ploy?
I think Octagon tried to pass the blame for the missing blind scan back to the factory they commissioned to manufacture the receiver?
Octagon never owned up to it being their fault even though the receiver had their name on it.
I will post some imagery later of the internals, it looks very much like the AZ premium layout (but not with that unique dual voltage supply)
Giblets.
The build quality is streets ahead of the 8008.
I've just realised (quiet at the back !) this 4008 has a twin terrestrial tuner , a TT3L10 which I am lead to believe is a NIM design.
The 4008 has one output as male coax, the other as a female fit, plus the legend on the rear is marked for DVB-S stuff.
Does anyone have the full specifications of the device as I think I can use it for a specific project. I've looked but no site I have found provides them, possibly as it is obsolete. I believe it was used in the VUPlus and Giga Blue range of 4K recveivers.
Thanks in advance
Hello,
I have a problem with my Octagon 4008. It is the first time that I have problems with this type of receiver, in almost 6 years.
So, after a storm late night I noticed that the 4008 remains in booting without passing this stage. Basically the only possible connection with the TV setup is by HDMI cable. I believe that this connection is damaged. But how is possible to restore the booting function my Octagon 4008 ?
Ive got a SF4008 with a really slow remote response anyone noticed this issue???
Like it doesnt respond the second time . If the button is pressed to quickly.
Bad Batteries ? change it...
Hello,
Its quite possible its suffered static damage especially if there were any nearby strikes.
Or a temporary mains supply surge may also be to blame (the strike may be further away from the property)
You could try to reinstall the firmware from a stick though you will have to start from scratch with personal settings.
Hello,
Thank you. The problem is that I can not load nothing by usb. And interesting I don't have signal from the LNB. I know that since I connected a Hightube 4K receiver and I don't have any signal.
Maybe you could remove tuner module and see if it boots then..
Hello,
If you had said that earlier.........
try disconnecting the incoming cable from the dish and check if it reboots/updates from stick
Then most likely a fused LNB and tuner (which looks to be a plug in device from images in Post 9)
Unplug and see if it then boots up.
