Octagon sf4008 4k uhd e2 updates 26.05.2019
Both tuner circuit boards and a USB upgrade ?
I give up. I had ordered a new receiver an Octagon SF 8008. I have good experience with them.
Thank you for all your help !
No, it does suggest the main board was - also - damaged, which would be difficult to identify and fix for the cost of a more modern receiver.
Did your 4008 have an internal hard drive installed ?
No. I used only external HDD.
OK. I would have suggested to remove the internal connections in the next message, but you could try to access the content on another device in case that has also been caught/damaged in the discharge.
Yes, I will do that. Thank you for the support.
Thanks for the upate here and your continued great work at Legit***........:Y
Wow !
Who retired / sold their box when Octagon support had been dropped ?
I never bought one for that reason...Blind Scan was promised but never materialised..
Might he a few on eBay now..lol
The results are truly excellent: the blind scan detects an SR of 952, and manually it can read radios with an SR of 400
