11330H - new image, PLS entered using remote control, no signal in DefineOS. 13dB signal using Open ATV.11330H - you must enter the appropriate PLS
11422H - not suitable for E2
11492V - required at least 11dB
Many thanks, I now have some progress.View attachment 158192View attachment 158191View attachment 158190View attachment 158189View attachment 158188View attachment 158187View attachment 158186
11422H - The Si216x cannot process the mode used
11492V - I don't have enough signal for LOCK
Used FW - 1.06.51
Success with 11492V now also, thank you.
I have both... not much difference... but with the M.2 slot the Supreme is the obvious choice.
You can add a 512GB MicroSD card I think, but signal is what matters in my opinion, unless you must have a super fast and large nvme ssd.I would suggest it depends on how many hours the older receiver has been in use, overall condition, and the selling price
Same here, the Silabs 2166D tuners are definately more receptive, especially within the lower range SR as opposed to the Avalink tuners fitted in the 'SUPREME' model.I've used SF8008 Combo for the last 6 years, sold DM920 inbetween and bought SF8008 Twin two years ago.
Both Octagons are older models, I prefer them for SiLabs 2166D tuners.
Wow that would be nice, they should increase the RAM to 2GB at leastThe next octagon SF 8008 supreme Version 3 is announced (no date yet) with Silabs 2166D tuner, which is not the case for versions 1 and 2 and with the characteristics of the other Supreme:
SSD SLOT internal integration of M.2 hard drives.
Bluetooth 5.1, use of a blue tooth Octagon remote control, so 2 usable remote controls including the original provided
All this is to be confirmed, this Version 3 has been mentioned since November 14, 2024
Avalink is more suitable for IP transponders that Silabs does not even detect (or has problems with).Same here, the Silabs 2166D tuners are definately more receptive, especially within the lower range SR as opposed to the Avalink tuners fitted in the 'SUPREME' model.
What are the use cases of such IP transponders?Avalink is more suitable for IP transponders that Silabs does not even detect (or has problems with).
Emailed who, if you would be so kind.What are the use cases of such IP transponders?
I have emailed them but they only confirmed that the tuners will be SiLabs and they didn't care about my recommendation.
They should increase RAM size and upgrade to DDR4, add support for SATA SSDs, add support for Android TV multi boot(other STBs with same CPU and SoC support Android TV), CI+ slot for custom CAMS.
I noticed that Vu+ receivers are dying because of the lack of updates, the Chinese are taking over now, this could happen to Octagon too, they have separate products for enigma and android, why buy two boxes when you can use one.
