40E Express AM7
These are really very good values today for NIKA TV too
DG Centre had a other Beam. It is very weak to receive.
Now is signal better. Video is demage.
I found 11066 V,400,2/5,S2 at 40.0E, and I'm not sure if it is at this position or on the neighboring satellites (Hellas Sat 3 or Turksat).
How about you guys?
Thanks.
From a thorough examination of the spectrum, carried out with Hardware and software for SDR. I see a low signal on IF frequency 1313,4 MHz, adding the OL frequency 9750 MHz, becomes 1313,4 + 9750 = 11063,4 MHz. It comes from 40°E from the Express AM7 beam Russia. The signal is too low to lock it, so I can not check the parameters if they coincide with those you reported, or maybe it is another signal.
now is the SR changed
I confirm, @dreamsat, what you found at 11066 V, now new symbol rate of 700.
I was afraid this mux might be from another position. It's hard to get precise directivity on the right position with a small antenna, especially when you have two satellites with strong signal on both side.
Thanks :Y
The 11469 H has today good reception.
New for me is 11058 H 21000 DVBS2/QPSK 3/4 Data
40e , "Ku fixed 3" beam according Lyngsat... Really Pakistan beam ?
@dreamsat do you received 11637 H ? From here 2db or 3db missing to lock:
Today, with heavy cloud cover, I manage 4.6 dB. On good days, up to 6 dB. Unfortunately, I've never unlocked it.
11636 H in the evening
11470 H has today a very good reception
the 11069 V is today very strong
