55.5w
  • Thread starter Thread starter Archive-8
  • Start date Start date
55.5° West - Cband
New for me - -
4126 H. 7500, 3/4,
Teams unknown at this stage ...
Hm, why then not on E2?!?!
The audio type may be defined incorrectly
Is there any contact from OpenATV developers or Octagon who could take a look into it and sort it out?!
New on 4.123 V, SR 5000, FEC 3/4, 8PSK, marked as encrypted but in clear at the moment.
3.845 H, RCN, 3 or4 channels are now in clear. EPG available.
3845H.webp 3845Hb.webp Caliente 1_20260331193234.webp Caliente 6_20260331192550.webp LAST Channel 7_20260331192843.webp
55.5° West Cband
New for me .... 3.859 V, 6399, 3/4. ID: Site 1. All encrypted apart from one.
What's the minimum dish size needed to be able to catch any thing on this sat from the SE England?
1.5m for limited reception
1.8m for reasonable reception
Great starter reply MB, the full answer to cover every aspect of C band reception is - 'How long you got' :)
A well tuned 1.8 using decent lnbf & feed etc for reasonable to decent reception, go bigger if possible.
For signal reception , forgetting other equipment required to demod certain stuff etc, I'm on a well tuned and aligned 2.2mtr PF here, that's my maximum physical size i can go to for my property, i would say for my location North Nottinghamshire, i'm at the 85-90% level for catching all reception signals - a 2.4m would get me to about 92-93% level , a lovely 2.8/3mtr upwards would be ideal for me to get the very weak feed or out of footprint beams , but i can only dream
VTV Venezolana de TV on 3.822 V, DVB-S, QPSK, SD.
