Revox AS-2000 Horn Antenna and Motorised Gibertini 105cm
remlap
Wales
Never bothered before to post any pictures before buying the Revox AS-2000 Horn Antenna.
Thought it maybe be of interest to people here.
Not finished adjusting signal levels yet, and cable and connectors will need to be wrapped in self amalgamating tape.
satelliteman
Interesting pictures, nice work.
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
Good work remlap, Will be interesting to see the results
I wouldn't have thought the Revox is still in manufacture. I did fit a few in the last century.
You really do need to cover up those connectors as rain is forecast in Wales tonight.
remlap
Wales
Couldn't say if somewhere they are being manufactured since its 2nd hand.
And its already been sealed :)
wod
yorkshire
nice, you could get away with a 1.2 gibby in that location as the small bushes would block out anyone noticing.with the brambles growing in there too
Retired Mod
www.timo.me.uk
That' so weird, I was looking at an ad for one of those Horn Antennas just the other day in an old copy of What Sat.
Nothing wrong with 'getting the horn', but how dog-eared was the copy ? ;)
Galaxis easy world
Germany
what for lnb did you mount on the revox as2000 antenna?
My next project is to change the analogue lnb into an digital lnb at my revox.
is this the standard lnb what is on your revox?
Thanks an greetings,
schnoerpel
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
The Revox antenna is so cool, thanks for sharing the pictures.
pdq09
Revox AS 2000
Wandlitz
Hi - did you ever get any further with your project to upgrade your Revox AS 2000? I have just found my old one in the cellar, and would like to change to digital.
Danke im voraus, für eine Antwort!
Galaxis easy world
Germany
Hi pdq09,
I bought a Megasat 23mm Single LNB and take a saw an saw away the rocket pin.
Then I change the old analogue lnb with the digital one, I get satellite tv but the quality is not fine.
(habe ein Megasat 23mm LNB gekauft,die Spitze abgesägt und schön abgeschliffen. Dann analoges LNB raus, Alu-Feedhalter als Klemme umfunktioniert und Feedhalter samt lnb an den vorhandenen Löchern angeschraubt. Sat-tv krieg ich, aber Qualität noch relativ schlecht).
Gruß schnoerpel
edbe
Eygelshoven NL
it's a nice satellite setup, you must only sometimes lawn the garden
jacqfranc
Hello,
I just bought a Revox AS2000 (new in the box, not yet received).
Can you tell me which LNB you put instead of the original one (some pictures would also be welcome).
MANY thanks !
jacqfranc
edbe
Eygelshoven NL
nice job and nice dishes
