Basic Cardsharing Server Set Up Tutorial
why me
looking for advice on diy satalite setup
uk
hi there
im new to all this im looking to set up sat system many off my friends have dream boxes on the hard wired system i can only use sat as we live in new build and they have not layed any network down, i have just read your tutorial and im intrested i have tried to do some research with google but but it seems to be in short hand lol. and im going round in circles.
is tutorial the latest version of iformation i will need on the best box dishes,software and tweaks, basically is there anyone out there who will take me under thier wing and point me in the right direction
thank you
mrdude
humax 5400
Thanks for this m8, I have been looking for a tutorial for a couple of days so this will come in handy.
lankey
dreambox
swansea
hi guy same here guy any luck with the tutorial setup
This thread is really only for the tutorial itself.
If you have followed the tutorial and are having problems then please post your question in a new thread. I'm afraid that this subject is quite complex and, whilst no-one is going to hold your hand and walk you through every step, when you hit a brick wall there will be people willing to help you.
You HAVE to be prepared to put the work in first folks. There's no easy route.
dreambox dm 500 with winmax
kenya
hey cool. pls note...once u download, remove the .tt n add dot pdf (.pdf) as in the extension or it will show as damaged file.
allans17
give the lad a break i thought it was an exellent tut :-)
mcquaim
No Satellite yet or receiver.
Windows Vista & Windows 7
Ireland
Hi there,
Is there a min broadband speed required for this to work well? I have 3mb download and 384kb upload but my sister gets quite a bit of glitching on her side!
She is on a 3G dongle so problem could be that side!
Any way to find out which side the problem is on?
Cheers,
mcquaim
The prob is almost certainly the dongle.
mcquaim
Ireland
Anything to check to confirm?
I'm after noticing also that both boxes are using different versions of cccam, 2.2.1 & 2.1.3. Would this cause any problems?
Replace the dongle with a proper bb connection :D
The problems are caused when the keys change - any slow updates (caused by a slow network link) cause a blackout until everything updates.
Transmission via a dongle is MUCH slower than via a wired connection
mcquaim
Ireland
I'm afraid that's not an option as wired bb is not available where she lives! The speeds she is getting on the 3G dongle are pretty close to my speeds but I guess with wireless the signal would be prone to break-ups..
Thanks for the help though!
In that case the appropriate is
tell her to stop being such a tight wad and buy her own subscription :-rofl2
mcquaim
Ireland
Haha, you might be on to something there!!
Any performance difference between different softcams or even images for this?
No. The problem is almost certainly just a slow update somewhere in the chain.
mcquaim
Ireland
An interesting update!
I decided to downgrade my cccam version from 2.2.1 to 2.1.4 and the performance it much much better! It really only glitches every now and again, pretty acceptable!
You would imagine an update in cccam would be more efficient...
permie
strong 4669 nilesat 201 90cm
Kenya
Hi, am a newbie and would like to know how to setup a cs server and client
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Get reading then buddy, no spoon feeding on this forum
alewis
T60, Manhattan ST200
England
Thats a really helpful reply ;-)
Seriously, can you provide at least a hint where to read, or what to read. Try learning from a google of ccam newcamd and you get pages of sites wanting to sell you a subscription, but little about HOW to do anything. A lot of guides are several years old, and now outdated. Sure, if you have been using this for a while you know what changed or how to install and config from scratch, which softcam to use, etc. When you are new, and the old guides do not reflect current reality, its confusing to say the least.
Just my two cent way of saying everyone was a beginner once, and needed help.
DishDick
Gran Canaria
Anyone able to send me a printable version as I don´t have full acrobat. Thanks
Use Foxit Reader 5 instead.
Much "lighter", free, and has Print features.
_http://www.foxitsoftware.com/downloads/
