Advice Needed 1.5m GIBERTINI or 1.8m Raven?
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Afternoon!
Bit of a tough one here. I have a 1.3m dish, I couldn't even tell you what brand it is, it's off fleebay. I use it to get feeds for various space launches for a project I work on. The dish is fine for these - usually - there have been occasions where the feeds are weak, especially during rain. I live in Fife, Scotland so reasonably north.
Feeds are usually on 10e, 4.9e. I also have a bit of a hobby of scanning for other feeds when I'm not working so I can't lie, having a larger dish to play with sounds exciting. :)
I've been thinking of what to upgrade to and I see two options but with big price differences:
1.5m Gibertini - Could risk putting that on a diseqc as I have a sheltered location. Dish, motor, concrete etc probably £380 range.
1.8m Raven - This is the tricky one, All the second hand ones on ebay are pick up only and I've yet to see one in Scotland, so the option I see if buying one from a certain store that does a complete package - £1600 range.
HUGE difference clearly. Both within budget however.
Question I have is, am I likely to see a huge difference between these dishes?
I have no experience in installing a polar mount with V Box motors etc, I like the sound of it though, And the photos of other folks installs they look very solid compared to a diseqc.
For £1500 I'd travel ooop north and install a motorised Precision 1.8 for you
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
theres no way a diseqc motor will carry a 1.5m gibby and it needs a polarmount/jack combo. i guess its down to price but be aware a 1.8m dish is huge, as is the 1.5m gibby but going from a 1.3m isnt that much bigger
sonnetpete
wordpress.com
Normandy, France
The 150 Gibby is available with either a polar mount or an AZ/EL mount but having looked at the photo I've attached you'd only get it on a Stab usals motor where the stub is mounted upwards. Even then it's not a project I'd contemplate, go for a polar mount and jack...
wod
yorkshire
You would be better off with 36volt system for a large dish/setup.
The speed of moving the dish too is better with a actuator motor for feed scanning.
What about a laminas dish from Poland, similar construction to a cm dish but lighter and still fibreglass based.
sonnetpete
wordpress.com
Normandy, France
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Don't even contemplate of putting a Gibby 1.5 on an diseqc motor. No way. I have two 1.2 m Gibbys on a diseqc motor and although they haven't given me any trouble I can 'sense' that's the limit they can take when moving along the Arc. The 1.5 Gibby that I have is mounted on polar mount. The first photo shows a 1m Gibertini Dish, the middle one is a 1.5, and the far end one a 1.2 Gibby mounted on a Diseqc Motor. Second photo shows a 1.2 Gibby. Photos taken the day before yesterday.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Understood. So any larger dish for me will need ditch diseqc motors - which makes me think, 1.8m is the ideal upgrade then rather than 1.5m as I have to replace everything anyway.
Quick google shows this to be a Primefocus? How does that compare in signal strength to the 1.8m Offset Raven?
Appreciate all the answers so far!
Aaron
I believe PF dishes are of lower efficiency but never tried it out in reality.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Google shows
1.8 Precision:
Gain @ 10.95 GHz 44.8 dB, Gain @ 11.70 GHz 45.6 dB, Gain @ 12.70 GHz 46.4 dB
1.8m Raven:
Gain 45.5 dBi at 11.95Ghz.
Couldn't find an exact match for freq but would seem the PF is a tad better, which is odd as like you say, I always thought PF's were lower efficiency as the lnb arm is in the view.
The PF is a bit cheaper.. Food for thought indeed.
I know that Raven make an offset 1.8m but is this a 1.8m PF? Size for size an offset dish will have higher gain (but lesser selectivity) than a PF due to the different f/D figure - i.e. a PF dish is deeper.
If the Raven is an offset then I'm baffled and suspect that the figures are not measuring the same thing.
Raven is offset and is the same dish as Andrews and Channel Master
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Thats correct and from what I read about, is the Apple Computing of dishes.. quality wise etc, Everyone rates highly of it. Precision I have heard less about...
Journey
drx 890
I recently purchased the raven 1.8m from a certain online store and it actually has the "channel master" branding on the back of the dish :)
wod
yorkshire
Precision dishes are made under another name now elite antennas something like that.
They are excellent quality as they are one piece spun aluminium dish, a lot lighter than a cm but much more easy to damage in transport etc.
Yes I know that. My point was that the gain figures are not explainable with the data given. As there are both 2.4m PF and 2.4m OS Channelmaster dishes available I was wondering if there was a little known 1.8m PF dish as well.
As I said, I am at a loss to explain it otherwise.
Yes, I am not sure either. My information came from others' say-so. I don't know whether PF will actually perform the same as a similar sized offset.
I guess a PF will pick up less ground noise as it's pointing further up towards the sky. But offset doesn't have various LNB arms in the way. I suspect there will be a number of factors in this. Manufacturer's gain quotes are likely to be theoretical rather than based on practice.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Googling around I'm being confused by a Primesat 1.8m PF, Is that the same dish as a Precision 1.8m?
I think they are different but not sure...
wod
yorkshire
These are who make precision dishes under a new name http://www.elite-antennas.com
Primesat are a brand name used by sat superstore I believe.
