Gibertini OP1.50 in costa blanca ... UPDATED!!
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
here some snaps of the great:-worship:-worship Gibertini OP1.50 with an updated setup ,the motor was reinforced inside-out with 2 strong matalic plates..the dish is pointed to Arabsat 30ºeast (C-band) for Aljazeera sport HD ...i beleive the signal is good enough with even 100/120cm in UK ....enjoy
satelliteman
Nice updated setup :)
[Envy]Superb![/Envy] :cool:
CROSSBONES
S.Wales
Class setup ;)
Satcom1
1 Meter Primestar Elliptical C/KU. Twinhan 1025 PCI(Linux), Coolsat 6000, Winegard 76 cm dish. 8' Unimesh, HCC9300 Receiver.
Diamond 9000 HD, 1m prime focus, 1.2 m prime focus, both on C Band.
Chicago
Pipino-
Very nice set up.
We can't get brackets for off-setting lnbf in USA. Most use conduit clamps and strap harware. Who is the supplier?
pipino
Back from the dead
Satcom1 said:
Pipino-
Very nice set up.
check satshop24(dot)de ,,he may have what your are looking for..cheers :)
Hello mate, it's looking good. What is the reason for receiving Al Jazeera from that satellite rather than a Ku-band transponder on 26ºE, 13ºE or 7ºW? Is it a because I can thing? By the way what makes are the C-band LNBs?
pipino
Back from the dead
hola Huevos,
that transponder from Arabsat 30ºeast is exclusive (Jazeera sport HD ,ESPN and NBA channels ) and we cant receive that transponder thru KU band from nilsat on a small dish here in costa blanca ,unless i we have a 2.40 up dish , so C-band is the solution in this case , i´m using Zinwell Dual pol C band LNBF for circular sats supplied by Tecatel and DMS BSC 421 for linear Polarity purchased from the USA ...best regards ;)
I forgot about ESPN. I just had a look at 7ºW on frequency 12456V and using the spectrum analyzer I can clearly see that transponder (about 3 clicks west of nilesat) but none of my receivers can resolve it.
hexah
Hadrians Wall
Very nice setup. :-worship
pipino
Back from the dead
just an update now we can pick up aljazeera sport HD on position 20ºeast ,easily received on a fixed 1.20m dish pointed at astra 19.2º using a C/KU combo LNB
pipino said:
a C/KU combo LNB
What LNB are you using? Does it fit in a standard dish bracket?
pipino
Back from the dead
something like this
_http://www.dmsiusa.com/specs/bsc621-specs1.jpg , forget performing for KU band its simply rubish but is enough for a fixed astra 19.2º ,if offset used you have to add this _http://www.dmsiusa.com/images/conical-1-150.jpg and lnb holder is case of gibertini OP1.25 or 1.50 _http://www.satshop24.de/satshop24/bilder/big/C-Band%20LNC.jpg ,i already have some spanish bars asking for it ,,remember al jazeera sport HD will be added if you have the espn (12us$ a year) option on the card...regards
Hakon
My setup
Laminas180cm P.M 60e-30w
24" SuperJack,Clark-Tech V-Box
Laminas120cm CM P.M 75e-30w
18" Superjack, Clark-Tech V-Box
Gibertini XP premium 100cm
Polar Mount, 12" Superjack
75e-30w
2 x Vu+ Duo
Sweden south
Like this a lot, professional setup.
Hi Pipino... sorry for the digging up a dead thread. Where did you get the C band feedhorn caps?
pipino
Back from the dead
my daughter´s powder milk :D
