Astra 1N at 19.2E
sky news good signal with 3.8m
7.3 db
I will answer myself ....
My sources have confirmed that the swichover for those TP will happen as follows:
All mentioned TP's will move from 2C to 1L, the date will be in the morning of 18/03/2014
i think will be end of march all tp move from 2c
As expected full strength here.
From which satellite?Because nothing is moved yet.... ;) Exept 1 transponder from C+ France
More than 1...
92 1L - 12.246V - Now 8.3dB (was 12.1dB )
105 1L - 12.515H - Now 3.8dB (was 12.3dB ) No lock
106 1L - 12.522V - Now 6.7dB (was 12.0dB )
108 1L - 12.552V - Now 6.0dB (was 12.4dB )
110 1L - 12.581V - Now 6.4dB (was 12.3dB )
111 1L - 12.604H - Now 2.5dB (was 11.4dB ) No lock
114 1L - 12.640V - Now 5.0dB (was 11.9dB ) No lock
116 1L - 12.670V - Now 5.8dB (was 13.0dB ) No lock
119 1L - 12.722H - Now 3.2dB (was 10.6dB ) No lock
12480v,12324v,12402v,down power
Its not true,just checked,everithing is still working...
very low signal
it mean signal also move soon
You must really hate 1N, eh?
Yeah... but maybe I should be grateful that at least some transponders are watchable (even if there is little room for rain fade) and certainly stronger than 2E and 2F.
Got a lock on 12.640V for the first time at 6.1dB this evening (was about 5dB this morning). Might be due to the daily variation or because it's a clear cold evening.
The horizontals are looking a lot weaker, but I suspect that is partly down to the LNB. Hoping that when they activate some of the lower frequencies with more tolerable FECs they'll be a little stronger (like 12.246V is "booming" in at 8.6dB at the moment).
March 5 , CanalSat migrated transponders :
TP 92 : 12246 V 29700 2/3
TP 105 : 12515 H 22000 5/6
TP 106 : 12522 V 22000 5/6
TP 108 : 12552 V 22000 5/6
TP 110 : 12581 V 22000 5/6
TP 111 : 12604 H 22000 5/6
TP 114 : 12640 V 22000 5/6
TP 116 : 12670 V 22000 2/3
March 6 , CanalSat migration transponders :
TP 86 : 12129 V 29700 2/3
TP 88 : 12168 V 29700 2/3
TP 90 : 12207 V 29700 2/3
TP 94 : 12285 V 27500 3/4
TP 96 : 12324 V 27500 3/4
TP 98 : 12363 V 27500 3/4
TP 100 : 12402 V 27500 3/4
TP 102 : 12441 V 29700 2/3
http://canal.engagement.dimelo.com/...1ed088f49/public_uploader/Chaine_1.PNG?082aa2
http://canal.engagement.dimelo.com/...311ee6abe/public_uploader/Chaine_2.PNG?82547f
So this means it was CanalSat 1L -> 1N last night and 1M Europe -> 1N tonight.
Oh no... I will not look TF1, France 2,3...:(
When was the last time you adjusted your dish? I just tweaked mine and got about 1dB or so out of it.
There's always 5W as well...
adjust the antenna today, but it does not give the result. More size is not possible. Can replacement converter. Available only 12515 H from zero to 1% quality.
