21.5E (Eutelsat 21B)
pontiend
Contibruter
south yorkshire
I did one yesterday.Lots of transponders were from 23.5.I think that all the 12000 ones were.
killdeer
West Lancs UK
Technomate 5402 M1, Vu+Solo2, Humax Foxsats HD&HDR.
Triax TD110, Inverto Black Ultra.
90cm Fibo with Invacom 0.3dB LNB (not up and running yet.)
62 East to 61West
Lancs
Just returned home after allowing my TM 5402 M1 to blind scan 21.5 east and found it had scanned in a staggering 295 channels of which 103 are supposedly FTA.
Some, of course, will be feeds or perhaps strong transponders coming from adjacent satellites, haven't had time yet to check.
As for the 11,558 transponder, I'm getting a very healthy 71% this morning, under light clouds. The blind failed to find the solitary channel on there and so I had to scan it in manually.
(Triax TD110, IBU, NW England)/
I see that Flysat a of yesterday was reporting the addition of a total of 39 channels on the 10,856V and 10,919V transponders, both SR 27500. All of these Arabic channels are FTA and come in at around 57% with light cloud cover and locking nicely.
Yup: See Post # 811 et seq.:)
peppey
looks like the MBC channels are on here,I wonder what mbc 2+2 is
no news channels though
Two radio stations with low symbol rate at 11577 H,sr.512,3/4:
MBrincat
1.2m motorized dish, VBOXII positioner, Titanium LNB 0.2dbs,
Dreambox 800HD
Malta
Are you receiving more transponders apart from those reported on Flysat?
If yes can you give us the frequencies?
I cannot do a blind-scan...
I'm surprised I managed one without bringing in 23.5E stuff: I seem to recall that happened during a previous attempt, so can only deduce my dish is a few tenths west of precise alignment.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
........ so can only deduce my dish is a few tenths west of precise alignment.
Yes, tend to do this purposely on several sats to avoid the 'invasion' of the neighbouring bird!.....difficult some times to seperate.
Yes, but the downside is maybe missing a few of the weaker TPs.
Ho hum!
Piltdownpaul
No.1 Spike Milligan Fan
I wondered how you were doing a blind scan without mentioning 23.5 tp's being logged. I cant blind scan it on the td88 it logs them all of Astra 3.
hexah
Hadrians Wall
Most modern receivers are a nightmare to jog slightly E or W.
Its essential for some TPs.
Receivers from the olden days of last century had the facility to do it directly using E and W buttons on the remote control.
Piltdownpaul
95% of my sats are stored diseqc 1.2, you can jog it in the menu to peak a tp, but not direct from a button on the remote.
hexah
Hadrians Wall
I only use the menus when I absolutely have to because it means loads of annoying key presses instead of a little dab here or a dab there.
The jog is so useful for weak TPs that it is a pain not to have it on the remote. I wish manufacturers would bring that back (and proper skew control).
It means that a dish farm is still the best option for weak signals.
Your acceptance angle is wider than mine, though - 1.1m dish has a narrower beamwidth. Possibly enough to make a big difference.
hexah
Hadrians Wall
Every little helps. :)
The bigger and narrower the better.
I think you can easily jog on with v boxes, so one of those as well.
Archive-8
Blind scanning with the tbs card I found these:
10855,V,27499
10918,V,27500
10960,V,1500
10971,V,2170
11247,V,14583
11288,V,1000
11310,V,7312
11328,V,22075
11360,V,2500
11493,V,2849
11523,V,2170
11531,V,2857
11558,V,1650
11619,V,12500
11630,V,2170
11690,V,1447
10793,H,27499
10918,H,45000
11127,H,10450
11341,H,26462
11478,H,2600
11667,H,1500
11558,V,1650
11620,V,12500
11630,V,2170
11673,V,3214
11691,V,1447
11669,H,1600
If yes can you give us the frequencies?...
Here is the list with transponders which I found today on Eutelsat 1A-21.6E.On this satellite I found the lowest symbol rate of all I've scanned.:11599 H,sr.256,3/4-2 Radio Service
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
according to @flysat 2 of the 3 new txp,s have gone multi-stream and changed sr to 45000... the 10.919/27500 txp is still listed as dvbs/mpeg2 but cant get a lock here atm
A4
10794 H
DVB-S2/QPSK
MPEG-245000 8/9Noorsatw E21B
Wide
new SR/FEC
Multistream 1
Al Kitab TVw F
14012401 Ara7001
Hogar TVw F14022402 Ara7002
Al Mayadeen TV Networkw F14032403 Ara7003
Alassema TVw F14042404 Ara7004
VIN TVw F14052405 Kur7005
El-Djazairia TVw F14064131 Ara7006
Syria News (Al Ekhbariya Al Soriyah)w F14082408 Ara7008
Numidia News TVw F14092409 Ara7009
Libya FM TVw F14102410 Ara7010
Rêgaw F14112411 Ara
34117011
Al Iman TVw F14122412 Ara7012
Awdehw F14132413 Ara7013
Libya TVw F14142414 Ara7014
Ishtar TVw F332415 Syr7015
Dzair Shop F14182418 Ara7018
Alkawthar TVw F14192419 Ara7019
Djurdjura TVw F14212421 Ara7021
A6
10856 V
DVB-S2/QPSK
Wide
new SR/FEC
Multistream 1
Karameesh TVw F
4041 Ara5
Taha TVw F1209955
4Shbab TVw F110119 Ara9001
Infone F210220 Ara9002
Zaytoonaw F571572 Ara9003
Jamawar Kurdistanw F311411 Kur9004
Green Life TV F451452 Ara9012
Mahbooba TVw F16172617 Ara
3617 Ara9017
Toyor Al-Janahw F20962097 Ara
2098 Ara9030
Al-Maaref TVw F308408 Ara9050
Libya Hasna F305405 Ara9052
Al Sha3ab TVw F41944195 Ara9055
Al-Quds Satellite Channelw F256258 Ara9060
Canary TV F33501 Ara9070
Bahrain TVw F4337 Ara9080
Marmarah TVw F314414 Ara9091
Al Masar TV Al Oulaw F180181 Ara9100
4Shbab TV 2w F300301 Ara9200
Noor Jordanw F421422 Ara9300
Noon TV Kids585000 Ara9330
Libo TVw F951952 Ara9500
-R- Jamawar Radiow 412 Kur9004
MBrincat
Dreambox 800HD
Malta
I have locked them both. Second transponder has some different sids from those reported on flysat
I think that change was inevitable >> The TP with the MBCs was Multistream right from the start
