Advice Needed 27.5w bbc1
marcoo
not yet bought
spain
Hi i live in spain, i have a technomate 1500 ci box, i have pointed it to 27.5w and set up to
BBC (11495 V 44100-9/10) frequency. But does not show signal?
marcoo
not yet bought
spain
This shows im on 27.7w but when i change to bbc freq it shows nothing, this is my lnb is it universal?image.jpg
Serafeim
5 dishes, Technomate 5402 M3
Arta, GREECE
Your receiver is not compatible. Bbc frequency is dvb-s2. You need a new, hd receiver.
Yup that receiver is too old to handle DVB-S2 frequencies. DVB-S only.
LNB is fine, though.
Kveys
Southern Finland
Are there really 11626V on 27.5W? It is behind of trees here, but frequency (and symbol rate) sounds familiar and can find from 24.5W (Televisa). Though it is Horizontal not V.
skomedal
This and that
thule
Op was just showing that he/she had lock on correct satellite 27.5W.
The correct freq. is :-
Intelsat 907 11495.00V
DVB-S2QPSK44100 9/10BBC-SATBACK
Regards
Kveys
Southern Finland
...so if she/he had lock really on 27.5W, there´s frequency 11626(V) in use?
skomedal
This and that
thule
According the the screen shot posted by the op s94 q 78.
But cannot find any active tps with that freq. on that sat. using KOS.
Am not that interested in this bird, as it hidden behind a 500 meter mountain:eek:
Regards
Kveys
Southern Finland
What I am trying to say, is that I believe the founded satellite position is 24.5W not 27.5W. On 24.5W has 11626 13500. Maybe her/his Lnb only polarity crossed around and thats why it shows Vertical as it should be Horizontal (if founded sat 24.5W what I believe).
skomedal
This and that
thule
Think your right! 24.5w.has that freq. active well spotted:)
As it was a old stb might have suffered sat. position overlap, they are quite close to each other 3 degrees between them.
Also this bird behind a great big mountain.
Regards
Kveys
Southern Finland
...and quite often people "trust blindly" what reciever say?!?! I mean many times people try to find some satellite and make channel search using definitely that wishing satellite. Then something finded and ooops mistake done. It really is some other satellite in practise. You can put what ever frequency for any of satellite and if theres signal then you should check what channels are founded to analyze, are you really there where you wish to be:)
Example->
There´s not KeravaSat (though I live in Kerava) on 1W:-rofl2
ps. hope you understand my english enough:)
skomedal
This and that
thule
Understand your english very well and your getting right to the point of the matter, well done:-applause
Regards
Retired Mod
www.timo.me.uk
KeravaSat? Is that coming from the giant golf ball?
Kveys
Southern Finland
KeravaSat?
Sure, it is one of the biggest secrets here. Only best channels send by it-> Rockabilly Tv, Teddyboy weekender Tv etc.:-rofl2
marcoo
not yet bought
spain
Thanks all, so the box im using is no good? And yes you are correct im on 24.5w just checked the channels, why does it say 27.5 w? Im using a first strike meter fsi.se too find the satellite would this find it? Thanks
Kveys
Southern Finland
Hello marcoo! These "normal" meters/boxes are basicly dumb repeaters. They handling only frequencies, symbol rates etc. Though there are identify data from satellites, normal consumer devices not take a stance on what satellite is in question. Pci-cards etc (and sure older enthusiasts) are the ones that makes identity clear.
BLUEPLATINUM
Maspalomas, Gran Canaria
I have been using this service for several years using a Technomate TM-5402 M2. Since then there have been many cheap Chinese receivers launched at very low prices. On paper many of these should work (suitable symbol rate and BISS) but I am worried that the user interface might restrict the ability to actually manually add the channels.
Please can anyone report back on any success stories regarding more recently available, cheap receivers ?
Many thanks.
