Trust
- Jul 18, 2004
- Age
- 78
- 1.8 m CM at SMR 1224 + Elev. with 7 lnb changer Ku (lin - circ) - Ka (lin - circ) C (lin - circ)
- Nijmegen Netherlands
Today did some work to modify my SMR 1224 for the use with Usals .
First removed the reedswitch en replaced the magnet wheel for one slot wheel .
Put the optical sensor board at the right place , there is plenty of room in there .
Set the limit switches to 80º E and 75 W making a 155º turn
Counted the pulses (430) with a separate counter , 2.77 pulses / degree
For Usals it must be approx. 39 pulses / degree so i made a 14 slot wheel (max. 34 mm dia )
Now counting 6050 pulses at 155º
Tested with my already with SG2100 circuitboard modified V-box , showed me its 100% OK !
