Dreambox 500 - JTAG Information
jben
beguiner
morrocco
Guys,
I would appriciate you help on the previous question.
Thanks in advance.
Dont be so impatient. Not all our members log in every day - some of them only visit once a week, and some will no doubt still be on their summer holidays. This time of year you need to give it a month minimum before you start getting jumpy about a reply.
zemogric
I used dm500aio jtag it said 100% complete but when i connect serial cable and use dreamup to load image it does not respond at all .any tips?
freon
jben said:
I have the same problem described in this forum. My DM500s is dead. I read several forums and I tried to upload a new image. I started to create a LPT cable and connect it to my DM500s (about 10 cm). Using jtag_windows and other jtag, I have the following error: Register Test Failed. Check cable connection.
I seen in some other forum that we can use DreamFlash for Windows v0.1
could someone give this tool (DreamFlash for Windows v0.1). Thanks for your help.
Does someone has any idea?
PS: I do not have tested using 100 ohms resistors yet.
Thanks.
100K are a must!
freon
max 232 defect maybe?!
onepic
DM500S
Have the same problem like zemogric and after flash with JTAG the green light is ON but the serial port is not accessible. I have already replaced the MAX 3243 with a new one but the same ;(. What else i can do to restore it ? Is there any way to flash the whole image with JTAG ?
Digi-Eye
i have dreambox 500s and openbox s12
Ireland
I don't see the 5x 100ohm resistors????
dogsbowlucks
Mac Dreambox 500S, 800SE
Always in Dog House
The 100 Ohm resistors are soldered on the parallel socket, 3,4,5,6,and 11 then you connect your wires to these. Don't forget the insulation. If you use a shop brought Parallel Socket it will already have 18-25 shunted.
wakibi
dreambox
uk
hi mate.which cam should i use to get premium contect.at the minute iam using astra 28degrees but i cant get the picture at all but i can get program info.please help
Do you have a subscription card? If so the cccam or oscam cams will read it.
wakibi
dreambox
uk
no,i dont have a subscription card.where can i get one?
freeidea
xp sp3 dm500 clone
morrocco
hello all,i try jtag my dm500s with 3 times successfully.after dm500s gemini image upgrade .but no it still no red or green led light ,and it can't response to dreamup?
tester2
satellite
canada
hi there,
any body post the DM500S WINDOW BASE J-TAG SOFTWAE I was unable to download any j-tag files from this site.
hopefully waiting for your reply.
thanks
tester2
satellite
canada
hi, I am looking for this Software for JTAG "DreamFlash for Windows v0.1"
hope some one post this file.
thanks
A nonymous
You can get a DM500s for as little as £30 these days. It really isn't worth the hassle these days trying to repair such an outdated box.
You would be better off just throwing it away and buying a new one, or getting something better.
tester2
satellite
canada
I appricate if you can help me for that little window base software, because I spend so many days on this box, I did soldering pins lot of mesh up in this box there after j-tag connection ok I got, so I want to see it come back to life again,
I tried with DOS, that is stuck in the middle saying "FLASH ERASE" then percentage shows 0%..., there after no progress , because INTEL unknown shows with alps tuner.
hopefully waiting for your help
thanks
Archived-1
Persona non grata
uk
thanks
The file you are wanting is quite easy to find follow this link.
https://www.google.co.uk/?gws_rd=ssl#q=dreamflash+for+windows+v0+1+download
" ................... other Search Engines are available ..................... " ;)
tester2
satellite
canada
hi guys, I tried with this name "DreamFlash for Windows v0.1" in google search from last so many days, there are so many sites comes up but no where that file I found.
still I am looking for this file "DreamFlash for Windows v0.1"
