For Sale ZyXel NSA 220 plus NAS Drive
A nonymous
I am selling my two ZyXel NAS drives as they are now surplus to requirements since i got a dedicated Dell Poweredge server.
Front, Only one NAS still has the protective film on it.
They have had very little use. One has just had HDDs installed in it and powered on (the one pictured) , the other has had about 3 months use. They come in the original storage boxes/packing but do not include any HDDs you will have to source these yourself. They use standard 3.5" SATA drives. I used 2x 1TB Western Digital drives in mine which worked fine.
Comes with PSUs and HDD screws. I think i know wher the manual is, if i can find it i will throw those in to.
I would like £22 for the newest one and £20 for the more used one. Free postage with MyHermes.
http://www.zyxel.com/uk/en/products_services/nsa_220_plus.shtml
System Specifications
Networking
  • Network protocol
    • CIFS/SMB
    • FTP
    • HTTP
  • Network setting
    • DHCP Client: Dynamic IP
    • PPPoE: Static IP Address
    • NTP (Network Time Protocol)
  • OS & File system
    • Embedded Linux Kernel 2.6
    • External HDD: EXT2, EXT3, FAT32
    • Internal HDD: EXT3
  • Security feature
    • FTPS
    • HTTPS
  • Backup feature
    • Self Volume to Volume Backup
    • One touch Copy/ Sync button
    • NAS vs. Ext-HDD Synchronization
    • Recycle Bin
  • Disk management
    • RAID 0, 1, and JBOD
  • USB application
    • Support Max 2 USB Printer Servers ( by CIFS protocol)
    • Support Pen Drive and External USB HDD
    • Support card reader
    • Support USB digital camera (PTP)
    • Support USB UPS monitoring
  • Power management
    • Idle mode
    • Scheduled power on/off/Reboot
    • Automated System Resume After Power Outage
  • Management
    • User/Group/Folder Management
    • Download status management (show the % of download)
    • IP Filter Table Management
  • System tools
    • Syslog
    • Support OS:
      • Microsoft Windows XP/Vista/7
      • Mac OS X 10.4/ 10.5
    • Support browser:
      • Firefox 2.0 and later version
      • IE 6.0 and later version
      • Netscape Navigator 7.0 and later version
Hardware Specifications
  • Drive bays
    • Up to 2 internal HDDs
    • Both SATA and SATA II interface supported
  • LAN
    • 1 x Gigabit RJ-45 Ethernet port
    • Gigabit Jumbo Frame Up to 9K
  • USB
    • 2 x USB 2.0 high speed
    • Type A female connector
  • Smart fan design
    • Acoustic Noise Level: 17.7 dB (normal speed)
  • Buttons
    • Power button
    • Copy/Sync button
    • Reset button
  • Power consumption
    • Hard disk spin down mode: 11.9W
    • Access mode: 23.7W
  • Power
    • Input: 100-240V AC
    • Output: 19V DC, 3.42A
Physical Specifications
  • Item weight: 1.5 kg (3.32 lb)
  • Item dimensions (WxDxH): 202 x 113 x 142 mm (7.95" x 4.45" x 5.59")
  • Packing weight: 3 kg (6.63 lb)
  • Pcaking dimensions (WxDxH): 284 x 185 x 278 mm (11.18" x 7.28" x 10.94")
Environmental Specifications
  • Operating environment
    • Temperatures: 5°C ~ 40°C/ 41°F ~ 104°F
    • Humidity: 20% ~ 95% (Non-condensing)
  • Storage environment
    • Temperatures: -30°C ~ 60°C / -22°F ~140°F
    • Humidity: 5% ~ 85% (Non-condensing)
Certification
  • Safety
    • UL 1950
    • CAS C22.2 No. 950
    • EN60950, EN41003
  • EMC
    • FCC Part 15 Class B
    • EN 55022 Class B
    • C-Tick
    • VCCI
    • BMSI
  • Power adapter
    • CEC Efficiency level V
Archive-8
Can it be modded for things like website/php host?
And what is the upnp player? Is it twonky server?
A nonymous
No idea, i only ever used it as storage unit, you would need to have a look on the Zyxel website to see what it can and cannot do.
Gerry and AS PM sent
I'll take the other if it's still available.:)
No problem, glad you got them both sold. :)
