It's a new one to me. On my gibatini op125l seven degrees of centre. And titanium c1pll.Nice find. If I'm not mistaken that was on Ses 6 at 40.5 circular. It's scanning in here with 13.9 db:
3808 V 26666 7/8 ETC, Zee cinema and Zee TV (SD/ HD) are FTA
Hi Feedsat........¿ Am working my way round the arc to make my first ever scan of 55.0ºW, is this frequency a good one for me to localise and lock with the 1.8m?
....and no need to suggest a polar mount is easier and as many here have hinted.
Thanks and enjoy the rest of your day.![]()
Thanks Feedsat....appreciate the info......be safe.My scans @ 55.5°W or 58°W are done with a 1.80m .
Yes, you can use this frequency 3808 V, a 7/8 but QPSK, the marging is good enough.
At the moment with 1.80m, here, the strongest TP is 4777 V 30000 in 8SPK: 11dB
good luck.
I am in the process of aligning 1.8cm on 55.5 west, firstly I found Bolivision on 4137, 2000 and with technomate 5302 mk3 got 70% signal, and 3 or 4 more tv. convinced myself a fence was in the way as from this forum , got into my head should be getting around 30 tp.
So I built a platform raising the dish 8 inches, but still cannot beat 70%, as the extra height has not improved reception, does this rule out the fence as an obstruction?
I am not experienced in c-band reception(my first try), but have noticed that I can move the dish a lot farther east/west. up/down and keep the signal, than would be the case with ku-band, is there anything to be gleaned from this, or is this the norm with c-band?
I am using a titanium c1-pll, I have 2 but one is slightly different as one box denotes wideband, the other not, is there a difference?
I know the difference between different lnb is minimal, but does the forum think there is a better alternative?
I have homemade arms and lnb holder, so everything is trial and error, based in the midlands, any views, answers, will be much appreciated, Cheers
could you please reccomend which I should buy then?OK, great, yes, with small antennas it's better to remove the plate, you lose about 3dB (and more dB with the titanium LNB , don't ask me why)
