Retired human
- See signature
- North Somerset
Pardon?
Not a trick question, did you, or did you not use any washing up liquid in the mix.Pardon?
Check the labels on both, then consult the periodic table, result is the same!Probably better to use proprietary plasticiser.
(else it would require a LOT more bags to fill it).
If I was to do this again, I would definitely get premixed concrete delivered. This was very hard work and the materials cost just as much as the delivered one...
Should have used Fairy,But you will be a lot healthier as a result (as long as you haven't pulled something ). The worst problem for me is the way the skin breaks up on the hands , usually moreso around the ends of the fingers, and the amount of bleeding that follows for about a week.
For hands that do dishes,
OK, made use of being on-call today (house bound) and the sunny weather and finished the stand. Had to slightly adjust the east/west plumbness with the threaded rods but it's all nice and straight ready to take on the dish.
Used some bricks we had stacked up to weigh it down and put the 'spare' frame on top upside down, so it's all nicely weighed down.
View attachment 92344 View attachment 92347 View attachment 92345 View attachment 92346
Tomorrow will be a less exciting day of laying the cable, painting the dish and I am under strict orders from the wife to tidy the garage, so she can put her crap in there....
But you remembered the Fairy liquid!Looking good C.J.
Nice to see this project taking shape ... and yes, i know only too well myself - that mixing concrete is damned hard work ... well done![]()
Please accept an Honorary Yorkshireman Badge.I bought a cheapo concrete mixer, then sold it on E bay, nearly got what I paid for it, happy days!
