Pipedream
Sheffield
2 channel master dishes with motors (1 meter and 1.2 meter), 4 lnbs, 4 receivers - 2 echostar ad-3600 ip viaccess, technomate tm5500 and 1 echostar 3000ip
motorised satellite system job lot
90 cm fibo gregorian
FIBO 90cm gregorian motorised satellite dish
Irte dish with actuator etc
Irte 130cm motorized Satellite Dish including mount and pole
1.5M satellite dish, no mention of the brand but i thought i'd post it...
Satellite dish | Caversham, Berkshire | Gumtree
I've put a bid in on the two channel master's not bothered about the rest just interested to see what the motors are. Don't want to pay too much its only the motors I am after
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
good luck, hopefully you get a bargain :)
At least one of them looks like a Jack arm - the seller mentioned 18", which usually refers to one. I wouldn't mind one of those Echostars as they have a 36v motor control.
Pipedream
Sheffield
Went for £53.75
Pipedream
Sheffield
Not bad at all, congrats. Show some picks when collected and installed.
It went for £53.75 but unfortunately it wasn't me that got it.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
That is a pity :cool:
saj1985
Lost...
someone got a bargain to be fair, better luck next time mate ;)
Pipedream
Sheffield
To be fair I don't rely need them, with two 1.2 cm a 15 IRTE and a 1.8 cm stuck in the garage. But if they had been at the right price why not.
saj1985
Lost...
yea when you get a bargain for the right price its hard to say no lol
btw the irte dish is still at £50 with one hour to go
Pipedream
Sheffield
What has that got to do with buying more dishes? :)
I was after the two 36 volt motors not the dish's, would of probably sold the dish's on
archive10
1.2m dish with polar mount, motor, etc
and also a 1.8m fortec star dishes (i think its one of those)
£25
Satellite dishes, stand, motor, polar mount and bits | Dawlish, Devon | Gumtree
Not a Fortec star / Jonsa dish. The petals look much more like plastic, so maybe something more sturdy and worthwhile (unless there is no hardware, as stated in the ad)?
The 1.2 meter offset dish looks very much like a Northern Satellite Corp dish (ie. not a Channel Master or Prodelin).
RimaNTSS
N-E from Riga
Yes, most likely it is NSC 1,2m, however my measured dimensions of it's working area is 1206 x 1348mm and depth 131mm. And I do not really undderstand what "overall depth" mean :-doh $_86.JPG
P.S. You will not believe.... I sold one of my dishes!!:cool: Now I have one dish less :oops:
archive10
Yes, most likely it is NSC 1,2m, however my measured dimensions of it's working area is 1206 x 1348mm and depth 131mm. And I do not really undderstand what "overall depth" mean :-doh View attachment 92793
Eh?? What happened?
A momentary lapse of reason?
