New Lnb changer
Archive4
Speaking with Louis van Gaal : I cant make choclade off it (real Dutch saying)
Geachte meneer , schrijf dat in het Nederlands , dus we kunnen de volledige impact van het gezegde te krijgen. Bedankt
Edit
dear sir, please write that in Dutch, so we can get the full impact of the saying.
Thanks,
Sorry almost forgot forum rule 126112365
Trust
Nijmegen Netherlands
Ik kan er geen chocolade van maken !
rule 126112365 ?? do you have a picture of that ? :p
Archive4
OK, it does not translate directly, but I figure it equates to " you cannot make a silk purse out of a sow´s ear "
OK , het niet direct te vertalen , maar ik figuur het komt neer op "je kunt niet een zijden tasje uit een sow's oor "
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
@Trust1, the 2 holes to the right was not your design, it was me setting it up.
you have provided 10 holes where i can put the lnb holder, origanally because i had good signal i used the hole 2 to the right, as soon as I corrected to the center all was good, and the signal became even better.
I am sure all on here would realise that they need to use the centre hole from the start, that is why i didnt explain, because it was obvious what I had done wrong.
Archive4
@WHATAGOAL1 , please post some pictures to help us all understand the finer points of the new arm and rotary LNB unit.
We almost went to " defcon 1 " tonight due to language variances across the forum. Thankfully, harmony has been restored with the help of Gods ( Forum that is, not theological ) we are now at peace, and ready to learn more.
Also, I like pictures!
Trust
Whatagoal , you are telling what you see from where you standing , we dont see anything , so how do we now whats left and right and what you mean by center ?
Do you mean the M8 holes in the wheel ? Why just not mention that ?
And center ? , perhaps point G ?
WHATAGOAL1
Leic
only 1 hole of 10 you provided can be centre hole at any time, when i move the motor with my receiver another hole becomes centre hole.
originally when i moved the motor the hole containing the lnb landed 2 to the right of center
Just a daft mistake, no one on here will repeat
Archive4
I´m assuming that 17.20 inclinometer reading was only for set-up purposes and not the correct reading?
@WHATAGOAL1 pictures speak a thousand words! ( Don´t make me post Telly Savalas ) too late,
We can all get lost in words, but not in pictures!
WHATAGOAL1
Leic
@Trust1 , exactly, in your picture you are using what i refer to as the center hole
Trust
OK that explains what you mean .
To have a definite middle center , where I put my Ku lnb , a choose in the changer motor menu "go to reference" and stored that for that lnb .
Since there are the most satellites with Ku , I choose for that option .
When changer settings are mixed-up , you can allways get the Ku lnb in the center and start reprogramming from there .
WHATAGOAL1
Leic
@Milamber, i dont know how to post pictures, the mrs has taken care of that in the past
Trust
Correct ! all those data is with front side dish vertical .
Trust
Everybody sees that picture , if I did not mentioned its about the wheel , I dont think they know what you mean .
Is it so hard to write , yes I'm meaning the WHEEL ?
Archive4
OH. FFS ( means oh flip, or dash-it ) why did you not say .........
Like I say, pictures beat words!
WHATAGOAL1
Leic
just been outside to look at my car, that has 4 wheels, none of them look like the thing holding the lnbs
Trust
