Advice Needed Thor Danish Channels reception west cornwall
Hosky
90 cm positionable VU Solo2
West Cornwall UK
The Danish channels on Thor dr1,2, and 3 and DRK amoungst others seem to have moved to a tight beam focused on Denmark. I've lost them now with my 90cm. Would I have a chance of getting them please if I upgrade to a Gibertini 1.25 m? Can anyone try in the south/southwest uk and see if you get a sniff of a signal? Thanx!
Mickha
North West
Please post frequency details, in future, it makes it a lot easier to check.
Just tried on my CM 1.2M, in the North West, and I have no problem with DR1 HD, on 10903 H 25000 DVB-S2 8PSK 3/4, in the 80% signal quality range, on VU+ Duo 2.
Hosky
West Cornwall UK
Thanks so much Mickha. The frequency I had was 10934 V 25000 but couldn't be certain that was current. I think it may be for the other Danish channels. Is it likely there would be much difference in signal between you in the NW and me in St Ives Cornwall?
Retired Mod
www.timo.me.uk
Signal levels seem normal here in Maidenhead for the Danish channels.
Hosky
West Cornwall UK
Ok thank you both. I will invest in a Gibertini 1.25 m and replace my fraccaro penta 85cm.
