60e Intelsat 904
blademedia
Sky
Thanks. What equipment are you using?
Hello, i use channel master 1.2 dish this lnb
http://www.chaparral.net/quad-lnb/
a must for weak signals, slingbox for when i am away from the uk.
blademedia
Sky
Kuban-rtv coming in today usually hard lock for me in afternoon
nelson_b
Contributor
Hi --
Managed to lock this t.p. the other night ( a first ) ... when i was testing out the inverted channel master 1.2 /Jaeger 1224 setup ... no luck under clear skies this afternoon though ..... :(
blademedia
Sky
Hi --
Hi, this position is hit/miss for me, in general the 11622/8527V mux is easier to lock in the day and Kuban in the evening with clear skys keep checking as/when you can all the best.
nelson_b
Contributor
Hi -
Thanks for the tip @blademedia ... yes locking that one ok :) see pic
and pic from the other night , re Kuban...
blademedia
Sky
Hi -
View attachment 97205 View attachment 97206
Good going :), I guess your still testing I noticed your post with inverted dish nice work:), 62E is a easy lock 40 channels $ feeds turn up though 66E a few radio lock 24/7 managed to lock one channel speda tv and a feed today 68.5 is easy to lock plenty channels open but mainly religious 70.5E one channel easy lock MTA a few HD can be locked in good conditions, will keep an eye on your reports :)
nelson_b
Contributor
Indeed - 62E is ok for me - thanks ...... no problem with the scrambled channel transponders :)
i never expected the sightly Higher/altered position of the inverted dish to make this much difference 54.9 E was my previous limit.....
I had a fixed 80cm mesh dish on 68.5E a few years back ... and although the signal strength faded in and out it worked quite well overall ... i may put something up again temporary, just for fun:). 70.5 is almost certainly out of the question for me here in the north west at 1.3 elevation.... and with quite high hills about 6 miles away ... i,m doing well to get 68.5 (2.4 elevation) i think :)
I have a full view west with the inverted 1.2 cm dish... but blind scanning last night...
i dont see any k/u signals beyond RASD tv at 45 W ... do you know of anything transmitting beyond there ?
blademedia
Sky
A barn roof about 25 metres away blocks me beyond 62E see pic .. View attachment 97221
Hi nelson, looking at the dish inverted/not in your pictures its certainly more in the clear I am convinced a prime focus will get you more arc if you have obstacles in the way that's one for discussion :oops:,
RASD is all I get west now in KU I can find data further up but nothing to view, some time ago I received channels from around 60/61W i don't preserver to the west maybe i should check more often you never know its all fun at the end of the day :).
blademedia
Sky
BTW 63E should be active soon ? maybe something to chase there ?
There are a few data streams on 58W in Ku but nothing to see really.
The RuSat transponder changed its parameters, much easier to lock now, it was very hard before.
11583 V 10000 7/8 DVB-S.
vlcsnap-2016-09-10-18h51m28s252.png vlcsnap-2016-09-10-18h52m24s203.png 60.0E-RFScan.png
blademedia
Sky
blademedia
Sky
Armenian Public TV. locking ok today 11622 v 8527
