26E (Badr-7)
Guess thay are saving Badr-7 for another mission ?
E M P T Y
Empty Position Band UpDated
Express-A4 (incl. 5.5°) 145.2°E C/Ku 20.04.2016
Astra 2A 115.5°E Ku 26.07.2016
AsiaSat 8 105.3°E C/Ku 14.08.2014
Eutelsat 36A (incl. 0.4°) 88.5°E Ku 03.04.2016
G-Sat 12 83.0°E 13.10.2012
Express-AM22 80.1°E Ku 08.05.2016
Intelsat 26 (incl. 7.0°) 64.2°E C/Ku 02.10.2013
Astra 1G (incl. 1.7°) 62.8°E Ku 12.08.2014
Astra 2D (incl. 3.0°) 57.2°E Ku 10.12.2015
Astra 1H 55.3°E Ku 11.08.2016
Astra 1F 44.3°E Ku 15.05.2015
Badr-7 26.0°E 19.06.2016
Astra 1D (incl. 7.1°) 47.3°W Ku 07.08.2015
Intelsat 1R 50.0°W C 08.11.2015
Eutelsat 65 West A 65.2°W C/Ku 29.03.2016
FlySat Sat List
Quote:-
"Operating a growing fleet of owned satellites at 20°E, 26°E, 30.5°E, 39°E and 44.5°E, Arabsat claims to be the only satellite operator in the MENA region offering the full spectrum of broadcast, telecommunications and broadband services"
I see that 34.5 east proposed next slot has now moved to 44.5 east o_O
mar-val
Slovakia,Zilina
MBC pack @ 11270 V 27500 5/6 DVB-S/MPEG-2 , listed as Badr 7 on Flysat now.
Here around 8db with 2m dish. ;)
Absolutely zilch here on the 1.8m. Not even a flicker.
FORKS
1.5M Gibby Dish 62E-40.5W ,75cm for 52.5 Turkman SAT,
+ Long 60M CT125 cable run , TBS 6983 , TBS 6922.
West London 51.45 N
Same here with a 1.5M in London. Not even a flicker.
Sounds like the end of MBC for us in UK. In FTA anyway.
Still working here ok 100cm Gibertini + Inverto Black Ultra + TM6902HD
Archive4
Nothing here on my 1.2 either, must be a well focused beam as I get 11919 H at 16 dB here at the moment.
Nothing here on my 1.2 either, must be a well focused bean as I get 11919 H at 16 dB here at the moment.
Is that a baked bean ?
pontiend
Contibruter
south yorkshire
I don't know if I am on the same wavelength or not but 11919H works fine here.
Only 51% though
TBS 6983 100cm Dish.
Nothing here on that transponder just a slight flicker if Badr-7 does replace Badr-4 that will be the end of 26 east here in Essex :(
Archive4
If it is on the said Badr-7 east MENA beam, would that not miss a large part of their intended audience? Surely, if it is intended to replace the existing 11919 H it would also be on the MENA bean as well?
BADR-7 - Arabsat
None of the test carriers from Badr-7 showed here in my location so this may be the end of 26 east subscription may be available from 7 west :eek:
fta MBC 26 east & 7 west ??
nelson_b
Contributor
Archive4
Hi @blademedia , it´s not on the MENA beam, but the east MENA beam, as per the link I posted earlier ( 35 ) even worse, I have no hope from here!
