zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
There were some Freqs changes on Sky UK, don't know if this is a normal routine or something to do with the arrival of 2G.
e.g Sky action SD had a freq of 11836 H 27500. Now its 11934 V 27500 5/6.
National Geo Wild had a freq of 11603 V 29500 DBV-S2. Now its 12187 H 27500 5/6.
Signal is slightly down by about 1db
i got 11790v 1.8db very low
after astra come i not any signal now i got signal after year and hanf
but it very to get lock
popolon
south west of Finland
Teleste 5m,invacom quad (28.2E), invacom quattro (26.0E). Triax multiswitch (1in, 8 out)
-TT 1600 PCI. Prof 3701 PCI.
-DR HD F15
-Ariva ferguson A120
Aerial 3m dish (7W-28.5E) + motor+ invacom quad.
-Ariva ferguson A220.
Finland
Tururu
Assembled with recycled parts
Recycled as the owner.
Just to thank the guys from the test.
As a report this morning, unwanted disappeared in the tp's 11053 --- 11171 the signal (Madrid) Spain that leaves tune tp 11053 H 23000 3/4 DVB-S2 signals.
Levels as usual.
Now all perfect, some pictures to show.
Simplemente dar las gracias a los chicos de los test.
Como informe esta mañana, desaparecieron las señales no deseadas en los tp's 11053 ---11171 la señal por (Madrid) España que no deja sintonizar el tp 11053 H 23000 3/4 DVB-S2.
Niveles como siempre.
Ahora todo perfecto, unas fotos para demostrar.
PD:Buena pesca/Good fishing.
Havent seen this info in a quick scan of the threads so -- info from DS member Strathclyde - ITV will be moving some of their tp's over to 2G UK beam probably overnight tonight.
Archive4
TKS for the info, will expect a few calls in the morning
2g not take pe beam tp ?
No other info about this one solly - the guy who posted on the other forum has always posted good info though. I see no reason to disbelieve his info though, he works in the broadcast industry so has access to info we dont.
At a guess its just to balance out the tp loadings.
M60
Northern England
All C band 2F TP's wil be transferring to 2G, not sure if this is happening tonight or tomorrow, the C5, ITV's and C4HD TP may switch first or at the same time as the BBC's.
Retired Mod
www.timo.me.uk
This will leave 2F with hardly any UK spots. Looks like 2F will be mainly used by Sky for Europe beams and 2E and 2G will be of most interest to Freesat and fringe viewers.
M60
Northern England
Yep, looking that way, with 2G for D band backup and 2F for C band backup. Sky have been doing more shuffling today with another TP illuminated (11.836H), a copy of 12.304H.
cazhh
Elmshorn, Schleswig-Holstein
tonight at 3:00 UTC something happened with 10964H. See attached image.
woborny
Well, if something happened last night, my 80cm dish has noticed no signal difference this morning - all channels coming in as usual...
cazhh
Around 2:30 11024H "jumped". It seems 2G and 2F have almost identical Beams then. We have to wait till the evening.
Archive4
Not sure if significant or not, but just checked 10964 H and getting 12.1dB according to Solo SE, compared with 11.2dB on 10993 H. Have not done the check before, so may always have been the case
woborny
Just seen that on KOS, they are saying 12226, with 5 Sky HD channels, is on 2Gs UK beam...
If that is true (givens KOS's past record of wrong beams) and it is indeed on the uk beam, then that beam is coming in here about 30% stronger than channels on the 2e and 2f uk beam.
Michal Norek
Czech Republic , South Bohemia
Satellite dish 1m 28,2E, IBU twin, DM 800 SE and Amstrad DXR890
Czech Republic
I have very strong signal on TP 11585 H in Central Europe.
TP from E28A sterable beam 1 have about 13dB.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
........dates as:-
05-03-2015
17-06-2015
popolon
-DR HD F15
Finland
That has to be wrong, as this 12226 is at same level as other 2F europe channels in Finland.
