I love that LogoWhy bother putting the Andrews logo on it!
Agreed. Unless you can somehow mould it to the dish surface, water usually gets behind any self adhesive material and it eventually falls off anyway.Why bother putting the Andrews logo on it!
I was going to cut exact shape with a vinyl cutting machine, it seems to last on other stuff outside.Agreed. Unless you can somehow mould it to the dish surface, water usually gets behind any self adhesive material and it eventually falls off anyway.
Why not design a rusty spoons logo insteadI was going to cut exact shape with a vinyl cutting machine, it seems to last on other stuff outside.
Going to change my name to RustyNuts I think with all these parts im messing with.Why not design a rusty spoons logo instead
Do they also think you are a spoon?Going to change my name to RustyNuts I think with all these parts im messing with.
Funny thing is, on USA based forums people think Rusty is my actual name
That's impressive! did you do that?Instead of sticker it is possible to aerograph image to the dish. Good paint will stay forever. I have 1.8m dish painted that way. View attachment 115877
I did only planning, transportation to professional painter and installation. Now I have this dish hanging on the sealing in the garage as a piece of art.did you do that?
You better not change this bolt. Firs of all scale will be lost, and secondly there is imperial thread..... not easy to find such a bolt in INOX (if possible at all). Existing one looks good enough.Most of the scale is still on there
No this bolt will not be goingYou better not change this bolt. Firs of all scale will be lost, and secondly there is imperial thread..... not easy to find such a bolt in INOX (if possible at all). Existing one looks good enough.
Nice work! I must buy another welder I thinkI've made several replicas of such bolts, but no scale and Metric thread. View attachment 115898
once you've painted the dish apply the logo and then put a coat of clear lacquer over the top to seal it on.Agreed. Unless you can somehow mould it to the dish surface, water usually gets behind any self adhesive material and it eventually falls off anyway.
