OCTAGON SX88 H.265 HEVC HD
Octagon also need to sort out the blind scan in the SX models. You set 13V in the satellite setup menu just to search vertical, and it scans horizontal as well and you end up with everything doubled. My other receivers can do it properly, so why not Octagon?
http://www.octagon-germany.eu/
It doesn't make sense to manufacture multiple boxes that are nearly identical in function. Better to streamline the range and offer wider variety between models. All that is needed from the current range is:
SF8008 Twin / Combo
SX88 4K
SX89 HD
Then a version of SX88 4K and SF8008 with CI+ would be useful to many people but instead we are offered the SF8008 Gold! An SF8008 with internal hard drive would be nice too :)
with internal HDD 1TB, 2TB soon. with in december.
few times reply, IS NOT Software issue ! is box issue, you need to send to octagon.
This is not as big a problem as previously thanks to the recent upgrades,
You must be aware that there is a problem with the tuner on the SX88 UHD with spasmodic picture breaking up this only lasts a few seconds but is annoying.
Thanks for your reply I will take up your offer & send the SX88 4K back to you as the DiSEqC motor control has lost its memory again & will not go to 13 east ect despite several attempts to reset the motor seems to have got more erratic since the last online update.
Plugged the SX88+ back in with no functional problem works perfectly.
What address do I send the SX88 4K to for you to check out & hopefully correct these problems.
So I send to this address:- ?
Necati Kücükogul
Anadolu Großhandel
Bündtenäcker 2
79730 Murg
Deutschland
I will write my name & address inside the box lid of the SX88 UHD.
I had one more try this morning before I packed it off to Octagon,
1/Update to the latest software via the Ethernet connection to the SX88 UHD,
2/Reset DiSEqC USALS,
3/Saved my settings to a USB stick,
All working OK now so there may have been a glitch in the software that I downloaded online ?
The only thing that does not work on the SX88 UHD is Heritage TV as the receiver cannot resolve UHD in H264,
The other UHD channels all working OK as they are in H265.
FTA UHD TV in the Ku band
FTA UHD TV on the SX88 UHD
42E 10980 V 12500 3/4 DVB-S2/8PSK HEVC TRT 4K
28.2E 12441 V 29500 8/9 DVB-S2/QPSK HEVC
Astra Ultra HD Demo & SES UHD Demo Channel
19.2E 10995 H 22000 5/6 DVB-S2/8PSK HEVC
SES UHD Demo Channel & UHD1 by ASTRA / HD+
19.2E 11288 V 22000 DVB-S2/8PSK HEVC
QVC Deutschland UHD
19.2E 12344 H 30000 DVB-S2/8PSK HEVC
QVC 2 Deutschland UHD
New = 16E 11595 V 30000 5/6 DVB-S2/8PSK HEVC
Ultra 4K Extreme
13E 10727 H 30000 DVB-S2/8PSK HEVC
NASA UHD
13E 11334 H 27500 DVB-S HEVC Hot Bird 4K1
13E 12539 H 30000 DVB-S2 8PSK HEVC
Fashion TV 4K
1W 12705 V 45000 DVB-S2/8PSK MPEG-4 HEVC
Wow 4K,Mooz 4K,NASA UHD.all H265
4K Heritage is H264 & locks up the receiver, so I
have deleted it.
Firmware (Software) Update V10535 02-01-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
SX89
SX889
Changes:
1. Fixed user agent wrong format.
2. Abertis fixed. 2 Decode Support.
3. Fixed long EPG name in EPG Menu.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10535.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10535.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10535'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ SE C/T2 & SE C/T2 WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
SX89:
SX889:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
Firmware (Software) Update V10539 30-03-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Fixed some Portal Protocol.
a.) Installieren Sie die aktuelle Firmware v10539.
a.) Install the latest firmware v10539.
a.) En son yazılımı v10539'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10548 18-04-2021
OCTAGON:
SX87
SX87 WL
Changes:
1. Sat-Finder eingebaut. 2xInfo Taste - Option Taste.
2. Stalker Multi MAC Nutzung eingebaut. (Stalker - Option - System)
3. Stalker Radio Hintergrund Bild eingebaut.
4. MAC Änderung über WEBIF eingebaut.
1. Sat-Finder added. 2xInfo Button , Option Button.
2. Multi MAC ID Support added. (Stalker - Option - System)
3. Stalker Radio Background picture added.
4. MAC ID Edit (change) over WEBIF added.
a.) Installieren Sie die aktuelle Firmware v10548.
a.) Install the latest firmware v10548.
a.) En son yazılımı v10548'i yükleyin.
SX87 & SX87 WL:
Online güncelleyin!
OCTAGON:
SX89
SX89 WL
SX889
SX889 WL
Changes:
SX89 & SX89 WL:
SX889 & SX889 WL:
Online güncelleyin!
Firmware (Software) Update V10540 21-04-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Sat-Finder eingebaut. 2xInfo Taste- Option Taste.
3. MAC Edit über WEBIF eingebaut.
4. Rütteln in PIG behoben.
1. Sat-Finder added. 2xInfo Button ,Option Button.
2. Multi MAC support added.
3. MAC ID Edit by WEBIF added.
4. Video Shake on small Window fixed.
a.) Installieren Sie die aktuelle Firmware v10540.
a.) Install the latest firmware v10540.
a.) En son yazılımı v10540'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10550 25-04-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. YouTube Kids ins Hauptmenü eingebaut.
2. TRT Cocuk ins Hauptmenü eingebaut.
3. Radio Hintergrund Bild ins STalker Radio eingebaut.
1. YouTube Kids added on Main Menu.
2. TRT COCUK added on Main Menu.
3. Radio Background add. on Stalker Radio.
a.) Installieren Sie die aktuelle Firmware v10550.
a.) Install the latest firmware v10550.
a.) En son yazılımı v10550'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10552 16-05-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Satellit 27.5W Programmsuchlauf Funktion eingebaut.
2. Multi-Mac Funktion verbessert.
3. Diverse kleine Fehler behoben.
1. Added 27.5W Satellite Channel Scan - Search.
2. Fixed Multi-Mac function issue.
3. Minor bugs fixed.
a.) Installieren Sie die aktuelle Firmware v10552.
a.) Install the latest firmware v10552.
a.) En son yazılımı v10552'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10558 07-07-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. OSD Sprachauswahl Menü im Start Assistent verbessert.
2. Funktion Backup - Wiederherstellung verbessert.
3. Device ID und SN Funktionen für Stalker Portal eingebaut.
1. Start assistent Wizard Menu improved.
2. Backup & Recovery function improved.
3. Added Device ID and SN option for Stalker.
a.) Installieren Sie die aktuelle Firmware v10558.
a.) Install the latest firmware v10558.
a.) En son yazılımı v10558'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
