OCTAGON SX88 H.265 HEVC HD
I have just received the new Octagon SX88+ Optima,
Excellent results so far I do like the new remote,
Blind scan works very well scans 10 east in less time than it takes to boil an egg,
Just one problem when I go to save my settings in Backup & recovery onto a USB stick only the DVB channel list is visible data that I can back up on the SX88+ Optima ?
On my Octagon SX88+ I can save all of my data onto a USB stick:-
DVB Channel list,
System setting
Stalker favourite groups
IPTV in Memory
CAM settings
Web TV data ect ect.
I hope this feedback will allow these features to be included on the Octagon SX88+ Optima,
Excellent work again Octagon :):Y
Blind scan works very well scans 10 east in less time than it takes to boil an egg,...
Does the blind scan allow for selection of a specified frequency range or is it the full band of a selected polarity or the full band of both polarities?
Full Ku band blind scan 10.7 to 12.75 V & H no selection available atm.
http://www.octagon-germany.eu/
Firmware (Software) Update V10518 22-03-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Add. E2TV - SatLess Multiroom TV Client-System.
2. Improved MYTV, WEBTV and FREETV.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10518.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10518.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10518'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
glassman2004
Octagon SX88+ Optima, Technomate TM-5403HD M3 CI Super+ and Humax Foxsat HD fed by motorised 1m Primesat dish. Windows 10 and OSX computers
Cheltenham. UK
hi
i am also pleased with my SX88+ Optima but I do not understand the reply to your bakup query. What is 4761. I cannot yet backup my settings,only channel list.
N.B. I have just installed the latest firmware 1.05.18
Cheers
hi
Cheers
Place a USB stick in your receiver then select back up if only the channel list appears then go back one step & select 4761 then go to back up & select what you want to save.
glassman2004
Cheltenham. UK
Great tx. I got an extra item " Dump firmware " Clicked on that; waited ages ("Please wait..." message) then when I clicked on "Settings export to USB" I got extra menu items to backup.
Cheers
Laser
Hi William-1. Thinking about buying the new SX 88 HEVC HD receiver. Now you have had it a couple of weeks . I was wondering if all was well and you had any further comments on the receiver. Thank you
The SX88+Optima is a brilliant receiver with an excellent handset very reliable signals from a sensitive tuner,
The Blind Scan is fast & accurate I am using the Optima with the 100cm dish on my System-1 = Panasonic 43" HD & the SX88+ with the 88cm dish,
My current System-2 Toshiba UHD 43"=100cm TM5502HD & 88cm with the Amiko A4K,
This way I do not have any conflict with remotes,
Laser
Thank you!
xyladecor
www.georgemichaelconcerts.co.uk
Dreambox 7020 HD, Dreambox 525, AX Triple X - Hirschmann 120 FESAT K IBU Twin - Sky Germany, Digi Slovakia, Telepiu
Vienna Austria, 48.21° N, 16.37° E
Is it possible in the meantime to recieve BBC Satback 27,5°W with the SX88(+) or any other of the current Octagon models?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Hola 'william-1'........hope you are well. Just arrived today the 'Optima-combo' (ordered after reading your comments/review:-clap). As you say, 'brilliant receiver' and handset, I like the handset keypad with the numerals at the top, seems easier to hold and operate than the original SX88 with numerals at the bottom....jusy my opinion!
¿Have you or anyone any comments re: the quality operation of the motor settings with the 'Optima'?
Thanks.....be safe:Y
USALS DiSEqC 1.3 is best for setting up a motor with the SX88 receivers.
My SX88+Optima is a single tuner satellite receiver.
Firmware (Software) Update V10519 11-04-2020
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. E2TV New Enigma2 WEBIF Version Support added.
2. 40W T2-MI fixed.
3. Stalker Infobar improved - Audio + kbps-
4. TRT TVTHEK added.
a.) Installieren Sie die aktuelle Firmware v10519.
a.) Install the latest firmware v10519.
a.) En son yazılımı v10519'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
OCTAGON E2TV Funktion (TV-Übertragung per Netzwerk-Streaming)
Genießen Sie das Satellitenfernsehen überall.
Ohne zusätzliche Verkabelung über Ihr Netzwerk wird Satellitenfernsehen auch auf Receivern möglich, die über keinen Satelliten-Anschluß verfügen.
Sie besitzen einen Enigma2 Receiver und möchten gerne in einem anderen Raum ebenfalls die Programmliste Ihres Enigma2 Gerätes nutzen, jedoch ohne weiteren Antennenanschluss und möglichst preisgünstig?
Mit einer OCTAGON SX BOX (SX88, SX888) können Sie es kinderleicht realisieren. Ihre Sender erhält es via Streaming von anderen Enigma2 Receivern, die sich im selben Heimnetzwerk befinden.
Neben dem TV Empfang über das Netzwerk, bieten die OCTAGON SX BOX (SX88, SX888) Modelle zahlreiche Multimedia Funktionen wie z.B. YouTube, Mediatheken des öffentlich rechtlichen Fernsehens und weitere.
Vorraussetzung:
Funktioniert mit allen E2 Images mit der aktuellen OpenWebInterface Version z.B. OpenATV 6.x, OpenHDF, OpenNFR oder OpenEight 6.x
