Advice Needed Radio France Culture
Retired Mod
www.timo.me.uk
Any luck?
Not sure if you tried to post something above?
hilaryanne
Archived Member
I have a humax fox free to air receiver and a PIXX ADT 1200 free to air
England
Brilliantly clear instructions thank you Timo
I am waiting for outcome but wonder should I have deleted all the stations again before starting.
38 radio stations
no france culture
1 radios ESP 10818 v 2200
2 radio ch 10818 v 2200
3 radio ch 10818 v 2200
4 radio ch 10818 v 2200
5 rock antenne 12148 H 27500
6 sunshine
7
9 DKULTURE 11953 H 27500
10
11
12
13 CANAL sur RA 11038 v 2200
14 radio maryja 11156 v 22000
16 radio beogr 10987 H 21992
17
20
21
22 radioch 11656 v 22000
23 radioch 11685 v 22000
24 radio Beogra 11023 H 22000
25
26
27
30 NL radio 6 11023 22000
31 RADIOS ESP 10837 v 21976
32
35 Canal sur RA 11061 v 21984
36 RadioCH 11678 v 21980
37 radio maryja 11185 v 22000
38 CANA l 11067 v 22000
I have just detailed the stations on new parameters
Retired Mod
www.timo.me.uk
OK this is positive as at least now they are on the right frequencies. I'll post some more instructions in a minute.
Retired Mod
www.timo.me.uk
This time I think you should try a manual search and see if we can tune in the French radio stations.
1. In the menu select Manual Search.
2. Select the same Astra 1 satellite name you used last time.
3. In the Transponder section (press OK to bring up a list) you need to look for and select Frequency 11568 or 11.568
4. Once you've selected this transponder you need to make sure these settings are correct and update them if necessary:
Frequency: 11568
Symbol Rate: 22000
Polarization: Vertical
Search Type: All
NIT Search: Off
5. When you have made all your settings press the Blue Function Key to start the channel search.
hilaryanne
Archived Member
England
Frequency: 11568
Symbol Rate: 22000
Search Type: All
NIT Search: Off
OK I could not find 11568 in the list only 11567 so instead I corrected it manually along with thesymbol rate. So all the settings were as instructed and pressed start but it found no channels whatsoever...
hilaryanne
Archived Member
England
My transponder was on 50 - is that why perhaps - not sure what it should be
Retired Mod
www.timo.me.uk
11567 is fine. What was the Signal and Quality readings on this frequency? You should see it at the bottom as you are looking at the settings.
Retired Mod
www.timo.me.uk
Also make sure you are using the same satellite as before, the one we edited earlier with the new LNB settings.
hilaryanne
Archived Member
England
These are my settings for the manual search
Satellite name Astra 1E
Transponder 50
Frequency 11568
Symbol Rate 22000
Polarization Ver
Search type All
NIT search OFf
I tell you this because at some point I decided to delete all my stations as there were 1000? tv stations but when I ran the search again I got no stations for TV or radio. I am not sure what I have done wrong...
Retired Mod
www.timo.me.uk
Do you see any signal or quality % readings as you look at the above info?
hilaryanne
Archived Member
England
Retired Mod
www.timo.me.uk
Hmm, that is the problem, there is no signal on those radio stations for whatever reason. I still suspect there is a problem with the LNB on your dish.
hilaryanne
Archived Member
England
Does that mean that if I wish to cure the problem I have to get the man out to change the dish? I cannot remember whether the dish was here when we bought the house in which case it would have been a sky dish and the man would have realigned it for my purposes or whether the man supplied the dish.
Anyway for the moment I have no stations at all radio or TV so please remind me how do I get them back?
Retired Mod
www.timo.me.uk
I'm afraid I think it does sound like there is a hardware problem somewhere. The dish should be fine but the LNB (the electrical bit sticking out on the arm) might be faulty. It could also be the receiver, but unlikely I think. If you have someone locally you could borrow a receiver from you could test it on your dish and eliminate that as the problem if it works.
Go back to post #117 and you should be able to scan in a few that still work:
http://www.satellites.co.uk/forums/threads/radio-france-culture.160628/page-6#post-873248
New tack: Do you have a BT Homehub?
hilaryanne
Archived Member
England
Yes
Turn it off and scan 11568 once more (For now, revert to standard Universal settings and Blind Scan)
Turn it on and report back.
Retired Mod
www.timo.me.uk
I'm going to have to leave you to it as it's midnight here and I'm off to bed! Good luck, will be happy to give any input again another day.
hilaryanne
Archived Member
England
Hello Tivu, I will try this tomorrow when my husband is not answering his emails....
