blademedia
- Jul 29, 2016
- Sky
- UK
Thank you for the explanation. I have another question if you can please help? Is it the distribution/depth of the scalar rings on the scalar or the forward/backward location of the scalar on the feed that matches it to the F/D?
Both, the scalar depth and size will match a certain F/D range,
Moving the scalar forward reduces the area of the dish that the feed can see, moving it backwards ( away from the dish) increases the area of the dish that the feed can see.
I notice that Chapparal and other vendors place a scale on the side of the feed to indicate adjustment points for different F/D with the same scalar. Presumably this works to some degree but is not the perfect solution?
This is a general guide as you say D not a perfect solution, without the proper equipment that will cost thousands of pounds its trial and error and can take weeks to get correct.
