blademedia
- Jul 29, 2016
- Sky
- UK
I honestly think its worth another go J, its all part of the hobby as you know, POSITIVITY is the way to go
Tease me with a possible design, need sketches, must have sketches
Understand your dilemma. Inability to switch between bands effectively is what's stopping me from deploying my PF.
Do you have room for a 1.8m? I guess your CM is making its way into Chris's garden!
I'm waiting for John to offer it to me.....lolUnderstand your dilemma. Inability to switch between bands effectively is what's stopping me from deploying my PF.
And I thought you loved me.......... I think he means the invoice CJ
One option to try, I have that many things bookmarked.
Thanks nelson, Any loss in C band signal I would presume not
I was asked earlier on in the thread what it would perform like on Ka or Ku, can't place either at true focus as this is a dedicated C-Band only reflector but can get pretty close to focus as a compromise.
Going to try this for a bit of an experiment & evaluation on the 2.2 ...... nothing to loose, easy as just changing scalar ring that has only one fixing screw. If it degrades C-Band performance too much then off it comes -- i have Ka & Ku bands covered already using other dedicated dishes.
Iv'e got a spare flat scalar, the same as what's in use now on the 2.2 for C-Band only.
Iv'e grafted the Inverto Ka/Ku onto it as close to focus as i can get.
Iv'e got reference readings and physical locations of equipment of dedicated C-Band frequencies documented prior to fitting the modded scalar to enable comparison.
Forget that idea then John, its no good
Just about to start a similar project John, I know its not going to work , but what the hell, ive got nothing better to do this afternoon ,
If I can get the dish to perform like a 1,8 in KU band and a 2mtr in C band I will be happy, anything above will be a bonus, I can always swap to a single LNB if I want to chase weak signals.
I had a Yuri combination like this on my Precision 1.8 (C/Ku) it worked really well.Only just seen this ... , Ka is a no-no, but it does work better on Ku when iv'e tried it in the past, and in those days we didn't have access to Ka stuff like we do today.
