3" Diameter steel tubing?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
T-plate adapter made from bits of T&K brackets:-
wod
yorkshire
excellent, post some more pics up when you get it working
where your other dishes are is there enough room to hide this dish lol from the other half to save getting earache
guest poster
registered
Robbo said:
Actually, a nut and bolt job, with a spare bit of angle iron, should do the job, maybe I'll try that next time on a longer mast.
I agree, if you don't weld a nut & bolt job.. like the braces on the 36"s..
Our local council has started using triangular "lattice towers" for some of the roadsigns on the A7 (Imagine a chopped down amateur radio mast).
Ive often thought if you could safely bolt a dish to it in some way using an adaptor plate they would make fine dish mountings for the garden - nice and easy to concrete in place and very strong thanks to all the cross bracing :)
