3W ABS 3A
Changing parameter now:
3919 V 9582 5/6 DVB-S2 16APSK
Big mux in clear.
Changing frequency...
3908 V 9582 5/6 DVB-S2 16APSK
PS: They tested a moment earlier with 32APSK 4/5 (unlocked)... missed to make a screenshot.
3907 V mux is now in 32APSK
Edit: NS2000 Tuner is not so bad, even with an unlock status, it works well:
I have attached below a few pictures from a scan of 3.0W in C-Band.
The test was done using a non polo pipe with a Titanium LNB shoved in the end of it.
The non polo pipe was cloned from the dimensions of an original ADL polo pipe and the scalar used for the test was an original ADL scalar.
It was a bit of a miserable result, only one viewable frequency locked from the East Hemi beam.
There are also a few data transponders that lock.
The position of the scalar on the non polo pipe feed was important for maximum signal level.
Among the pictures attached below there is a small table that presents the signal level variation for various scalar positions along the feed barrel.
To complete the test I need to adjust the feed throat aperture 5mm closer to the dish and 5mm further away from the dish and repeat the signal level measurements for various scalar positions.
Possibly something for another day.
Non Polo Pipe (ADL Clone).webp 3.0W_CBand_IQM_VPol.webp 3.0W_CBand_FeedScalar.webp 3.0W_CBand_4114V_SR3333_p0.webp 3.0W_CBand_4114V_SR3333.webp 3.0W_CBand_4114V_SR3333_p2.webp
Following on from yesterdays test on 3.0W in C-Band I have compiled a small summary table of the results.
I included the data frequencies that registered a signal.
There are quite a few West Beam frequencies for 3.0W but the UK is some way out of the footprint.
I managed a small flicker of signal at 1.3db from 4000H, SR2500 which is a West Beam frequency but needed another 3db to possibly lock it.
Anyone with a 3.0m dish in the UK might just about be able to lock this frequency from the West Beam?
Table attached below.
Had a look here with the old 3 m Prodelin ... only up to about 2.db - from 4000H, SR2500
A blind scan revealed 2 channels at 4012 V 5000
Footprint thins out quite rapidly as we go further North Nelson doesn't it :D
Tricky bird to catch, even in Ku...
my signal with 2,20m
With 1,80 Channel master
3882V1666 Channel TV (identifier titan3)
and 4114V3332 Africa
3882 despite 8.4dB it takes a long time to get a picture (also with TBS 6983 and VLC)
my scan
my reception in vertical with 2,20m
I am planning to try to find the signal on 3W C-band frequency 4157 H 45000 (ESPN). Has anyone managed to lock this signal? I will try with my 2.4m CM dish. If anyone has experience, I believe a member here has the same type of antenna with double reflection. Can a C-band LNB work in combination with a smaller reflector?
the signal of CruiseSat hac today a good condition
3653 V 53380 DVBS2X extention with embedet HEVC Video
Here are two more transponders with S2X extension
3745 V 68568
3825 V 68568
Building up CruiseSat on 4.157 H...
my current scan
