57E (NSS 12)
dreamsat
germany
my reception today. The 10985 H had no picturs
stephan94
Bavaria
with a surface 4.2 times smaller (1.80m)
here are my results.
I am not complaining.
dreamsat
germany
update at transponder 11545 H 30000 DVBS/QPSK now is better receive
Nesiha TV is new
dreamsat
germany
11105 H 45000 QPSK 5/6
dreamsat
germany
11545 H 30000 QPSK 5/6 has normal performance again
stephan94
Bavaria
This morning, I was able to receive " three" transponders from the East Africa beam (without lock),
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
57E East Africa bundle.
Here I managed to do something Lock-. Location Slovenija-gibertini 150.
dreamsat
germany
11165 H 45000 DVBS2 3/4 very tight everything. no clear pictures
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
A little bit missing to Lock
dreamsat
germany
11105 H 45000 DVBS2 5/6
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Nice- where is your location and what antenna are you using.
dreamsat
germany
my location is saxony in Germany and my antenna is a ANDREW ES 37 (3,7m)
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Very nice antenna size-, heavy category. Do you have any pictures of this beauty.
dreamsat
germany
my reception today
dreamsat
germany
11545 H DVCS2/QPSK 51418
This transponder appears to be interfering with the East Africa beam or the transponder has been switched off
11544 H was active at 11044 H, probably the two spots Africa East and Central Asia, as they do not interfere.
Yet the two spots meet in parts of Europe and other continents.
I don't know how it is in other areas, but because 11544 H,51428.5/6, 11545 H, and 45000 have about the same frequency, I can't hope for more than a trace signal, mainly since I "hunt" it with a small antenna.
Here is what the two spots look like at two different times: the first is from last year, and the previous is taken today.
And yet, although you can't see 10984 H on the spectrum, this morning, I managed to lock it and watch TV services with the 6909x card and neumoDVB.
It's impressive what @deeptho managed to do with this card under Linux, with a signal at the limit of reception. That's not possible on Windows.
dreamsat
germany
After the signal on the 10999 H has continued to increase, the 10985 H can no longer be received. 1 dB below the lock threshold.
That's how I thought 10984 H left this slot today, but from the window, it looks like a mux is still active. Probably because of the interference of 10998 H, the signal at 10984 H is even weaker and impossible to lock.
Here is the signal(2.5dB ) I have at 10984 H at the moment, of course, without being able to receive it.
I managed to lock 11544 H,51418,1/3,a CNNI feed in the generic stream on the Central Asia spot.
dreamsat
germany
The signal on 10999H has now become even stronger and I can only imagine the 10985H. The transponder 10999 H can no longer be unlocked for me.
