Amos 5 @17E ?
Kveys
Southern Finland
Salvation Tv 3786R 1166. Many other freq. give signal but not lock atm.
pride21
Sandown Isle of Wight
that's the only channel I am able to pick up it was showing a blank screen.
Kveys
Southern Finland
[QUOTE="pride21, post: 879718, member: 233155"it was showing a blank screen.[/QUOTE]
So vhs-tape stopped at last:-rofl2
Kveys
Southern Finland
TVT1 (Togo) 3664R 1447.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks for the heads-up on this one Kveys ..
Finally a decent signal at 17 East to get a lock on..
Easily lockable on my offset LNB also..though a full 2db lower
rgds
VS
Kveys
Southern Finland
Yep, good thing is strong signal but it was disappointing channel (also 10E as you knows). Allways hoping countryes like Rwanda, Burundi, Lesotho, Malavi etc. new ones, when getting new signal from 17E:)
And also Namibia has black point though it might sending east hemi from 64.2E. I am sure that first time when I shall get something from 64.2E upper frequencies it will be 4040R rel. TBN not 4043R One Africa Tv:-doh
Funny reciever this new TM-f3/5. It have problems with C-band channels what using sr 1000 (10E strong TCV and 22W Viasat 1). It found them on blindscan with strong signal but cannot show either. It behave like there´s no signal at all? Same with normal manual scan, nothing.
Otherwise it competite well with for e.g f15 if I look back findings and signals from them. And also very nice that it find all low symbol rate channels quite well. It´s helpful specially in C-band.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Helluva drop in signal level ...
Down easily 6db ..
also changed Vpid and Apid ...41 and 43 Hex now ..
Same frequency and SR ...so Transponder rescan needed.
Still lockable here but under 6db now..
I suspect it wont be long before this channel too is shifted out of range of Christina ...like everything on this bizarre bird..
rgds
VS
Kveys
Southern Finland
3635L 4167 Optima1 (scrambled). Optima sports changed from 4147R??
Kveys
Southern Finland
3686R 2000 Oromia Tv +2 radio. Flysat only feed but maybe regular now here?
Retired human
Can someone please give me the strongest transponders for me to try on this bird?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The only constant from 17E at my location CJ is Oromia ..and that's weak at best ..
barely lockable on Christina ...so I would seriously doubt getting any results on a dish less than 1.8m..
Other channels have been stronger ...usually the god squad stuff ..but not constant thus hit n miss.
rgds
VS
Kveys
Southern Finland
Did you mean VS that "old" Oromia freq. 3626R or new 3686R? Just checked that 3686R and it is clearly stronger today than what was yesterday (Optima 3635L same strenght as yesterday). But as we know that bird (17E) working very odd generally.
But for CJ -> 3686R clearly strongest today but tomorrow some other might be the one:)
Kveys
Southern Finland
3635L 4167 seems footy feed from Brazil for Optima sports. It says "scrambled channel" but when matches are playing, then it is fta. Signal here just under watchable (fragmentary).
3626 Oromia now Ok but last weekend 3686R was there also (now nothing). Also first time here locked 4138R Dove Tv but it was so quick that when i founded camera it was gone:-ohcrap
Kveys
Southern Finland
Tonight both Oromiya frequencies working (3626R/366R) same time but different programmes. Same TVO logo anyway and though upper quite weak it is easy to check that there is not any TVO2 etc. inside the logo. So 3686R maybe some kind of their feed or..? They are sending Euronews now.
Shame that 3635L Optima feed so weak tonight and cannot check is it fta or not when footy starts soon.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Both Oromias locking here too ..
3686R solid at 7.5db and 3626R at 5.5 db ...
both showing the same programming atm.
rgds
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Sorry Chris ..I cant confirm or deny ..
Simply can't find anything at 3901 ..
Checked both H and V (L and R) .. 17 E
not even a hint..
Is it still there ??
Having said that ..I'm not locking either Oromia atm ..so maybe a TOD thing...
rgds
Retired human
I haven't seen a squeak from this satellite... not even a flicker of signal. I suspect the house is covering too much of the dish at this location - though 20E is booming in with most TPs hovering around 9-10dB mark.
