Amos 5 @17E ?
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Amos 5 with cirkular right polarity and two locks between 3,86GHz and 3,93 GHz:
3874 R 918 and 3913 R 3334
@Chris1979
your lock on 3901 was with linear vertical polarization?
>>> Can´t be from Amos 5 @17° E
Archive-8
@Chris1979
I had the lnb set to curcular polarity (L/R)
dx qwer
Rastatt/Germany
Thanks, Chris1979!
Amos 5 with cirkular left polarity and three locks between 3,88GHz and 3,94 GHz:
3891 L 6877, 3922 L 10531 and 3932 L 6666
All these carriers and also these from cirkular right spectrum are a long time there active (with unchanged parameter), so it can´t be from Amos 5.
Archive-8
Thanks, Chris1979!
Then I am going to have to refind the transponder.
Thank you for checking.
dx qwer
Rastatt/Germany
3901 R 45000 DVB-S2 is from Eutelsat 3B @3°E.
Thanks to Feedsat on "Sat DX Club Deutschland" today.
dx qwer
Rastatt/Germany
Eutelsat 3D moves to 7°E (than renamed in Eutelsat 7B ), but Eutelsat 3B is on 3°E.
Kveys
Southern Finland
I started a blind scan and went out with dog (Holiday now). When I came back there were founded 3547 R 3750 (not enough signal to lock. So dont know what channel) and 3682R 2000 (stored channelstv-c). No any signal atm. So cannot verify that it might this Nigerian channel Channels. Oromia also very near 3686R so be carefull with it!
Kveys
Southern Finland
3998L 2000, strong signal but no channel->feed?
Retired human
Still struggling to get a lock on this satellite.. about 2-3dB on this TP.
Kveys
Southern Finland
Symbol rate now 1000 and signal even stronger than earlier. But TM F3/5 doesnt find any channel.
Retired human
Yes! Finally got a lock on this satellite! Nothing scanned as you say but... I locked it!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..A little Salvation from this freaky bird tonight ...
exceptionally clear skies...and Salvation TV easily lockable 3786R 1166 @6.4db
..and a bonus 4035R 5000 @3.8db ....sadly a data channel
..as is 4177R 15677 @1.3db
Archive-8
[SATTYPE]
1=0170
2=C-Band
3=3
4=0
5=5150
6=0
[DVB]
0=1
1=3884,H,12905,34,148,|-47 dBm, -0.9 dB
pride21
Sandown Isle of Wight
hi all I just tried this bird since I altered my dish got Oromia tv at 4.7db,Salvation tv at 4.7db and 3848R at 4.2db which is a data channel.Dove is showing 7.2db no lock probably needs a bit more gain.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
GTMedia V8 UHD
GTMedia GTcombo x 2
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
New bird for me......no chance with the Ku footprint:-
Technomate 5402 also locked 3686 R 2000... same tv channel as 3626 R 2000 but title shown as 'OROMIYA_TV' (all capitals) both showing what seemed to be a funeral!
New one was 3682 R 1922 'ADTEC TV'
gafsa
180 c/ku band
tunisia
3851 1000 R MITV
Tests on Amos 5 with two C-band lnbs, one circular-Galaxy-Innovations, the other linear-Eurostar,both with the same noise figure-17° typ:
dx qwer
Rastatt/Germany
3682 R 2000 5/6 DVB-S2/HD 8PSK
Still on with Channels TV from Nigeria.
...maybe not a feed?
