iggy said:
Poland is somehow "divided", western part (Poznan, Leszno, Wroclaw) has very strong signal, stronger then Astra2D, but eastern part (Krakow, Warsaw, Lublin) doesn't even see a thing.
yet more proof that the new-generation Astra satellites are capable of producing a sharply defined illumination zone with a quite abrupt signal drop-off on the edges, resulting in minimal overspill.
This is only just the beginning. And on
digitalfernsehen.de, somebody has been pondering why we have such unbelievable signal strength reports from all across Western Europe... consider this: Astra 1N was designed to provide two pan-European beams at 19.2E. It was only in the later stages of preparations for the 1N mission that it was announced that 1N would be sent on an "interim mission" at 28 degrees before being repositioned at 19 degrees. So would it have made sense to spend potentially millions of euros on changing the hardware layout and adding a third mirror just for a UK spotbeam, if that mirror would only be used for a little bit over a year?
Remember when Astra first published a map of the new 1N UK beam about a year ago (and quickly retracted it again) which showed a wide illumination zone across Europe, including a strange sidelobe west of Portugal in the middle of the Atlantic? Remember, since yesterday, we have even had reports from the Canary Islands that they now get 1N's Channel 4 HD with a large enough dish. Here, take a look...
In reality, it could be that this first map was in fact accurate, and what could be happening at the moment is that one of the two pan-European beams is being used to serve Britain. And because it was never designed to be a narrow UK spotbeam, it illuminates half of Europe. Once 1N is transferred to 19.2E, that beam will probably be nudged a few hundred kilometres east, which will make it fit perfectly over continental Europe, if you look at the map.
So what's going to happen once Astra 2E relieves 1N at 28E in two years' time? Probably 2E will have a UK spotbeam for real, meaning Europe will lose the signal. It will use the same kind of technology which now means Western Poland gets 1N, while the eastern part is looking at blank screens.
