astra 1p 19.2e
I have an analog receiver (TechniSat ST 3002 S) and a Philips CRT TV on my setup and you can see black screens on the strong carriers which have these ring shaped IQ constellations.
I observed different testing modes for the transponders on 1P being tested:
1. full bandwidth mode - lower power -> no "ring", no "black screen"
2. full bandwidth mode with narrow high power carrier at the transponder's centre frequency ->ring and black screen
3. full bandwidth mode with narrow high power carrier at the lower margin of the transponder (around -12 Mhz from centre frequency with a "tusk"-shaped spectrum on Crazyscan) ->ring and black screen
4. the same as 2. but without full bandwidth "basement" carrier
It is interesting to note that in some tests there are lower power peaks at the opposite polarization which seem to be switched on and off. I have a mechanical polarization skew motor on my setup which is optimized at 9.5 deg West.
ses astra testing signal freuqncy like astra 1n
max11
Motorized 180cm /3m fixed dish
Nowhere
analog signal not use dvb2x
Analog signal conditions is different , its easy to get unlike DVB-S2 , so it's early to tell
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Westport 53.81N,-9.54W
11393 H
11767 V
stephan94
Bavaria
thank you Welikan
this is what IQMonitor can define
