siena_us
Si, certo, se non da noia a nessun altro. / Yes of course if it doesn't bother anyone else.
Is it okay though if I respond in English ?
Originally posted by barney
riesci tu avedere tuuto il north beam?
In che ore ti arriva il segnale del 2d?
Quale convertitore avevi prima, e quale hai adesso?
Abbiamo lo stesso ricevitore, è il migliore addirittura quando si puntava la parabola con il misuratore di campo non agganciava il segnale, mentre con il digibox il segnale era ok.
Originally posted by Old Satellite
Your results on 2d are interesting, can you copy and confirm the dish performace information.
It will be some thing like 49.6 db at 12 GHz, I will then run a few calculations to see what the 2D expected results should be.
Originally posted by corrigap
>>Someone requested the "What Satellite TV" report on Invacom LNBs?
Yes, that was me. No need now, but thanks anyway. Hopefully it might be of use to someone else.
I took the plunge a month ago and bought one (single, offset), but the results were disappointing. So far, none of the 10 or so LNBs I've tried has been as good as the Eurostar 0.5 I started with. My next tack is to try to get a feedhorn from Gibertini and then get a flanged LNB, but I don't know which one yet.
Peter
